Critically Damped (Q=0.5) Subwoofer
Old 17th November 2003, 05:20 PM   #1
tktran is offline tktran  Australia
Account Disabled
Default Critically Damped (Q=0.5) Subwoofer
Does anyone have experience with the Critical Q subwoofer?
http://members.ozemail.com.au/~joeras/sub_index.htm
I got lost one-third down that page, so I tried modelling the Peerless 12" XLS 830500 driver in WinISD 0.44 using both the manufacturer's T/S parameters and the measured T/S from Vacuum State, but did not get anything as expected. So I plugged the values into
http://www.diysubwoofers.org/sld/sealed.zip
and when shooting a for Qtc = 0.5, resulted in a Vb of 33 and 26L, with -3dB points of 60 and 70Hz respectively.
Is this correct? How can this be considered a "sub"woofer?
Does the subwoofer amplifier use some sort of Linkwitz transform circuit or LF equalization? I must have missed it, because could not find anything on the website.
Old 17th November 2003, 05:34 PM   #2
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
He's EQ'd the sub by modifying the amp. There's also a disclaimer stating that if you've never modded an amp to chose another amp the meets the criteria. He freely admits making changes to the power amp section can be tricky. There's a section titled Sub-Amplifier Components Changes where he outlines which components to change to particular values.
Old 17th November 2003, 05:41 PM   #3
Account Disabled
Oh I see. So the EQ can be achieved without doing the "Optional & May Be Very Difficult" Power amp module mod?
Perhaps it will be just easier for me to try shove a 12" Shiva in sealed 50L box...
Old 17th November 2003, 07:15 PM   #4
Timn8ter's Avatar
Actually, I think you can achieve very similar results with the Adire DPL12, PE plate amp and a ~75 litre sealed box.
Old 17th November 2003, 07:32 PM   #5
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Below is the simulation by Subwoofer Simulator, written by our own F4ier, for a Shiva in a 50 liter sealed box.
The lower white line is the response in "half space" the way most simulation programs do it. The upper white line is the response with the average amount of room gain.
The room gain is from an frd file written by our member Serow.
The purple line is cone excursion, which actually seems to match quite well with the Shiva's linear excursion.
Even with room gain, the response is only 105 dB at 20 Hz-not great. At 30 Hz, though, you get 110 dB with room gain-pretty good for a box not even 2 Ft³.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 17th November 2003, 07:59 PM   #6
Wizard of Kelts
PS: Just want to add that the above simulation was for a Shiva with both coils driven in parallel for a 4 ohm total load. The voltage level was 28 volts, which into a 4 ohm load yields 196 watts.
The reason I selected approx. 200 watts is that reasonably priced sub amps are available in that power range. The Shiva can take more power than 200 watts, if you want to provide it.
PS: The original link that was given for this Critical Q subwoofer was here:
You will find that there is a room gain graph given on that page. I would just point out that is the same graph that Serow used when he wrote file for room gain that appears in the graph above.
-Anonymous
Old 17th November 2003, 09:28 PM   #7
Dave Jones is offline Dave Jones  United States
There's nothing novel about this design is there? Isn't it just another low Q sealed box system with bass boost? I'm not impressed by the unsubstantiated claim that it's better than some unnamed servo systems. What's the big deal?
Davy Jones
Old 17th November 2003, 10:06 PM   #8
Wizard of Kelts
Actually, you are right to a certain extent, and the web page author is right to a certain extent.
A sealed sub with a Qtc, (that is the Q when the speaker is put into a closed box), of 0.5 will have less overhang than a servo sub if the woofer has a higher Qtc, like 1.5. The 0.5 Qtc means that "overshoot" is naturally controlled, and that this natural control is better than a higher Qtc rating with sevo control.
The disadvantage of Critically Damped subs is that the output is 6 dB down from the midpint at resonance. This requires a big boost by the amp to bring the output up.
The big advantage is of course, the natural control of the sub.
Here is a thread which I think explains a lot.
http://www.diyaudio.com/forums/showt...114&highlight=
I should point out that a sealed sub, even with a Qtc of 1.3 or higher, has less distortion than a ported sub. It is usually easier to get higher output at lower frequencies with a ported or Drone Cone, (Passive Radiator) sub. To which can be added the fact that distortion is less hearable the deeper the bass frequencies.
Still, some people feel the sealed sub's lack of distortion compared to the ported box's is quite hearable.
I believe the author's aim was to give the beginner a fast, relatively inexpensive way to make a reasonably sized sub that will deliver clean, quick bass.
-Anonymous
Old 18th November 2003, 12:14 AM   #9
Bose(o) is offline Bose(o)  Canada
Currently I am in the proccess of building a 53L box for the Shiva. The three litres are there for the woofer and bracing, making the system effectively 50L. I believe that I calculated a required 165W of power to achieve Xmax in that enclosure. I love the Shiva driver already and have it sitting on a proto-H-Baffle woofer enclosure that I have.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 18th November 2003, 12:17 AM   #10
Account Disabled
Joe also gives options for 3 versions- Audiophile LF (restricted LF), Audiophile and A-V.
But the only real difference between the Audiophile (intended for music) and AV (better for movies) is that the AV version has a subsonic filter.
How can this be detrimental to sound quality? I had always thought that a subsonic filter is a "good thing"
Critically Damped (Q=0.5) SubwooferHide this!Advertise here!
Do Old Timers listen more critically? Shaun Everything Else 5 8th April 2008 11:43 AM
CD Player: DIY Foam Damped Spring Feet $8.00 x-pogo Digital Source 0 7th January 2008 07:17 PM
Damped (lossy) BR ports Pjotr Multi-Way 36 13th September 2006 06:44 PM
Somebody damped that discussion over here Fred Dieckmann Everything Else 17 23rd July 2003 10:01 PM
