Old 24th January 2013, 11:24 PM   #31
sebDIY is offline sebDIY  France
Measurement (calibrated) from one of my MTH:
Old 25th January 2013, 03:01 PM   #32
tb46 is offline tb46  United States
Hi sebDIY,
Thanks for that. It basically confirms the Hornresp simulation (real life smaller peaks, etc.). How high up do you use it?
Oliver
Old 25th January 2013, 08:58 PM   #33
Thanks for posting the chart, what were the measurement conditions?
What drivers did you use in your cabinets?
Looks like a classic example of Hoffmann's iron law, low, loud, small, pick two.
In your example of the MTH, the lower octave of typical pop musical bass is sacrificed for small and loud, response is 25 dB down around the low B (31.5 Hz) on a bass guitar.
As usual, smoother than Hornresp would predict.
Old 25th January 2013, 10:28 PM   #34
I want to see the impedance response curve. That will show how close the sim matches the actual design.
www.diysubwoofers.org
Old 25th January 2013, 11:35 PM   #35
Looks like a classic example of Hoffmann's iron law, low, loud, small, pick twoClick the image to open in full size..
For my use it's perfect. I was searching a light cabinet (mine is 23Kg with ferrite driver, this is the lightest of all cabinets I've tried), searching also clean sound, and it is, with ability to make strongest level in this size. I have compared with some 18" bass reflex. The 18 BR goes lower, but MTH-30 makes more level and is more dynamic, also lighter and smaller.
The loudspeaker is LF12G301 RCF, measurement groundplane 2 meters without any wall into18 meters perimeter
Without any any eq, you can cross at 110/120hz without hearing any ugly resonance, but I think it is usable above 120Hz with Eq cutting peaks. I know some people cross it 150Hz. I use most of the time for wedding: 2 MTH-30 and 2 ZX1 EV. I have made 200 people without any problem in this configuration and I think it can do even more.
Old 25th January 2013, 11:48 PM   #36
Oliver's (TB46)Hornresp FR peak and dip locations matching senDIY's measured peak and dip locations indicate the sim matches the design very closely.
I find it interesting that most in the DJ and PA business are perfectly willing to trade LF extension for SPL.
Art
Old 26th January 2013, 12:08 AM   #37
Art
Lots of small pa setups don't use subs, so in comparison this is very good.
Old 26th January 2013, 12:23 AM   #38
"Very good" is a relative term, like "good enough".
The Mackie HD1502, a fairly small speaker on a stick using a 15" and 1" exit HF driver drops off only 1/6th octave above the MTH30.
Old 26th January 2013, 12:26 AM   #39
Most wedding rooms I work got reverberation, and can sound "whaouwhaouwhaou" in the infrabass range, espacially with very compressed music, so I prefer, from far away, a truncated and dynamic bass cabinet, more listenable, than a slow sub.
Old 26th January 2013, 01:00 AM   #40
Art
Well, for me at least, I'm not "in the business", so to speak, it's a hobby. I specifically need something "one man" portable." If it's not easy to grab and go, I just won't take it. No 18" sub, and most 15" subs are not just grab and go for me.
Well, I'm still debating on what exactly that I'm going to do here, I'm fairly certain that I'm going to build at least one pair of small 12" TH subs.
I have some more pedestrian questions.
First, does anyone have any specific recommendations for the following items:
1) Connector plates, I want to use speakons.
2) Finish, I'm leaning towards some sort of paint, but I want to know what people like and use, and what's cost effective.
3) Handles and pole mounts.
Given the simulation results and measurements here, I'm not seeing a lot of difference between the low frequency extension of the MTH30 and the THAM12, which is a bit smaller. I also notice that hornresp really considers only the dimensions of the horn and the properties of the driver, and how the horn is folded, holding all else constant, doesn't come into play in the sim. I have no sense of how the quality of the horn fold impacts real results, but, given what I've read elsewhere on this forum, performance is relatively insensitive to small deviations holding all else constant.
Consequently, it appears that I can trade off some SPL for LF extension in the THAM12 by just making the cabinet about 3 to 4 inches taller. After that, it appears to be diminishing returns for additional length. I simed this using the 12PS100. Looking at the design, it seems that I could scale the height in the build plans fairly easily without dramatically affecting the taper of the horn or any other critical dimensions. Anything that I'm overlooking here?
Finally, I haven't sim-ed it yet, but, I'm leaning towards the B&C 12NDL76 for weight reasons. Any thoughts on this, are there any other good choices of driver in the 10 pound range that I should consider? In particular, is there anything less expensive that would work almost as well?
tnx,
gs
Running Home audio in my car. Complete Noob. leochevalier91 Car Audio 16 18th December 2011 10:53 PM
Advice for/questions from a complete noob to amplifier DIY. jaistanley Class D 10 18th November 2010 08:32 PM
complete noob question beauistheman Chip Amps 19 10th August 2009 06:37 PM
Complete noob needs help tstarn06 Class D 5 10th March 2008 09:03 AM
Complete noob to all of this, help to my feet? jesuslovesyou Subwoofers 5 4th September 2007 01:51 PM
Copyright ©1999-2013 diyAudio
