#11 | |
I could use my analog rat shack SPL meter with correction data to pull some numbers, if I get around to it. Running full range music, bass heavy, I've hit over ~115db peaks in the middle of the room, the RS meter is accurate "enough" for that, without the system breaking a sweat or the subs near xmax. Last edited by turbodawg; 23rd January 2013 at 04:29 PM. |
#12 | |
.You claim a response 8 dB above a manufacturer's specification, and have not bothered to put a dB meter in front of the cabinet? Please show us the Hornresp input screen and FR that result in an 8 dB sensitivity increase over the manufacturer's specifications and a measured response at a few frequencies. |
#13 | |
#14 |
[QUOTE=ghettosynth;3338791]Thanks, to be clear, did you mean 6 of the MTH30? I read in another thread that the 12ps100 didn't simulate well in that cabinet so I want to make sure that you aren't talking about the THAM12?
Hi! Yes, 6 MTHs. 12PS100 has a strong cone, good xmax 8mm, 700W Pe, goes low, and plays nice innit from 40 till past 100Hz, with good and defined notes reproducing the bass guitar. To me is more than enough. Make one and hear it with your ears, measure it, ... Compare it with what you have and make your decisions. Isn't it this driver in the Danley miniTH? Why? How much is the sensivity claimed? Think that the SPL/response should be measured within the band it will be used, as a subwoofer, and not when the thin cone or drivers dome plays full range as could be observed at the drivers PDFs. Due to the cost of it at my country decided on the 12CL76, which costs half compared to the 12PS100. Is a bit more sensitive so final SPL within limits are near same, also sound is near like it, but the cone is not so strong. No, not the THam 12. Regards,
PASC |
#15 | |
As far as I can tell, the DSL TH Mini uses the B&C12TBX100, which on paper is a tiny bit more sensitive than the BC 12PS100, 2 Hz lower Fs and has 9mm Xmax and 11mm Xvar, and 300 watts more power handling. In my testing of the BC18SW115 I found the Xvar excursion and rated power handling completely usable, so if one can afford the 12TBX100, it is worth the extra output potential in whatever box it is in. Still using the Keystone? Art |
#16 | |
Using the Dayton Reference 15 in a simulation of about 90L net (20x22x16 using 3/4") 2 volt with a 35 Hz Fb does show 95 dB at 60Hz, 91.96 at 40Hz, but only 89.34 at 35 Hz. At 30 Hz it shows 85 dB. Hornresp is very useful, but it often shows peaks larger than reality, and drooping upper response (or more LF response) than real measurements. Comparing the real measurement of my Lab 2x12" to the sim, the sim shows the response at 40 Hz to be some 10 dB higher than 500 Hz, while it is actually 2 dB less. I built the Lab 2x12" before using Hornresp, that peaky port "boom" Hornresp predicts would have scared me off. If the same holds true for your Dayton Reference 15 in a 20x22x16 35Fb box, it may be closer to 87 dB than 95 dB sensitivity. Art |
#17 | |
12PS100 Item Price: $205.95 12TBX100 Item Price: $294.95 Difference............+ $ 89.00 43%more per driver. If you have the money for the difference of cost and and so for bigger amp to earn some 1.5dBs ok. Not have chance to test the 12TBX100 yet. When tested in the TH18, the 18TBX100 beside 18LW2400, it didn't impress me so much. 2000W to do the same as the 18 Sound one with 1300W, and travelling a lot despite carefull low-cut set. Keystone: Despite good results, after tests, shame it is parked at my garage as is the TH18. Driver costs to much here due taxes. But was a good study to me. Regards,
PASC Last edited by PASC; 23rd January 2013 at 07:16 PM. |
#18 |
HornResp doesn't take losses into effect, if I remember correctly. Gotta be a bit careful when using it to sim vented boxes.
www.diysubwoofers.org |
#19 |
Do you have access to HornResp predictions or actual measured FR or PR response curves for the MTH30?
#20 | |
.I'd like to see sims, actual measurements, or direct comparisons if anyone has made them, but found none in my quick review of the MTH30 threads I came across. Maybe Pasc could compare the MTH30 to the XOC1 TH18 or my Keystone and give us an idea of FR, sensitivity and output potential. |
| Running Home audio in my car. Complete Noob. | leochevalier91 | Car Audio | 16 | 18th December 2011 10:53 PM |
| Advice for/questions from a complete noob to amplifier DIY. | jaistanley | Class D | 10 | 18th November 2010 08:32 PM |
| complete noob question | beauistheman | Chip Amps | 19 | 10th August 2009 06:37 PM |
| Complete noob needs help | tstarn06 | Class D | 5 | 10th March 2008 09:03 AM |
| Complete noob to all of this, help to my feet? | jesuslovesyou | Subwoofers | 5 | 4th September 2007 01:51 PM |
