MTH30 Questions : Complete Noob!
Old 9th February 2013, 04:42 PM   #171
kornnylike is offline kornnylike  United States
Originally Posted by tb46 View Post
Hi Djim and kornnylike,
What is the dimension from the mounting edge of the speaker to the triple roll surround (tip of the rolls and approximate center)? That still looks a little deep based on kornnylike's data in Post #159 (15/32" - 0.46875" [11.9mm]).
Tb46
Post a drawing of what you asking and I will measure it for you.
Old 9th February 2013, 05:28 PM   #172
tb46 is offline tb46  United States
Default Post #171
Hi kornnylike,
Are we over-working the dtails yet? :-) Please, insert your measurements.
Oliver
Old 9th February 2013, 05:58 PM   #173
turbodawg is offline turbodawg
Originally Posted by KMossman View Post
I recommend MDF - it is stiffer, and less likely to resonate. If you use plywood then use the thickest you can, and consider more bracing,and stiffeners.
Keep the internal dimensions the same.
Don't know where you dwell or the conditions but you might to consider using marine grade - less likely to 'fall apart' when the humidity is high.
MDF is heavy! I built a mini-platforms [with casters] for when I had to move my LH transmission line speakers.
Plywood is both stiffer and lighter than mdf, but not as damp, ply is by far the prefered sub and pa material. 5 ply is stiffer and cheaper than many-ply baltic, but can have voids. I recently built with half inch ply with great results, braced properly.
Old 9th February 2013, 08:02 PM   #174
Hi kornnylike,
Here are the measurements
Old 10th February 2013, 06:40 PM   #175
Hi Y'all,
Here is the updated side view of the B&C 12PS100 with approximate areas for consideration in AkAbak @ S4, and possible cone correction:
Oliver
MTH30 Questions : Complete Noob!Hide this!Advertise here!
Running Home audio in my car. Complete Noob. leochevalier91 Car Audio 16 18th December 2011 10:53 PM
Advice for/questions from a complete noob to amplifier DIY. jaistanley Class D 10 18th November 2010 08:32 PM
complete noob question beauistheman Chip Amps 19 10th August 2009 06:37 PM
Complete noob needs help tstarn06 Class D 5 10th March 2008 09:03 AM
Complete noob to all of this, help to my feet? jesuslovesyou Subwoofers 5 4th September 2007 01:51 PM
