#161 |
#162 |
Hi kornnylike,
Thanks for the additional data. I assume, that the overall dimensions are correct (I derived them from the manufacturers data/drawings)? Regards,
Oliver |
#163 | |
Keep the internal dimensions the same. Don't know where you dwell or the conditions but you might to consider using marine grade - less likely to 'fall apart' when the humidity is high. MDF is heavy! I built a mini-platforms [with casters] for when I had to move my LH transmission line speakers.
Getting back into business, though non-audio related. Have excellent contacts for NEW [OEM] Russian and Chinese tubes. Custom chassis, and parts [MOQ applies] |
#164 |
Hi Y'all,
Here is an updated drawing of the B&C 12PS100 showing the dimensions for the cone, and the area needed for cone correction in the middle of the driver. Regards,
Oliver |
#165 | |
Tb46 I recheck all the measurements of the b&c 12ps100 cone dimension several times to make sure that they are all correct.
#166 | |
Looks like you can test the same volume correction (first stage) of post#131 together with a centre brace, for the Tham12. It counts for both models of the PD.12SB30, old and new. Last edited by Djim; 9th February 2013 at 12:45 AM. |
#167 | |
How did you measure the depth from the front to the centre of the dome and the depth from the edge of the dome to the front? The reason I ask is because TB46's model, based on your measurements seems odd. When I checked my own drawing it looks like you measured the depth from the edge of the cone (where the cone ends and the surround begins) instead of using the real front See picture;
#168 |
Djim and Tb46
After reading Djim post I recheck all the measurements and found that few of them was a little bit off. This one I make sure it was measured correctly. Please let me know if you guys need anything else B&C_12PS100_drawing_06.jpg |
#169 |
Hi Djim and kornnylike,
What is the dimension from the mounting edge of the speaker to the triple roll surround (tip of the rolls and approximate center)? That still looks a little deep based on kornnylike's data in Post #159 (15/32" - 0.46875" [11.9mm]). Regards,
Oliver |
#170 | |
Post a drawing of what you asking and I will measure it for you. |
| Running Home audio in my car. Complete Noob. | leochevalier91 | Car Audio | 16 | 18th December 2011 10:53 PM |
| Advice for/questions from a complete noob to amplifier DIY. | jaistanley | Class D | 10 | 18th November 2010 08:32 PM |
| complete noob question | beauistheman | Chip Amps | 19 | 10th August 2009 06:37 PM |
| Complete noob needs help | tstarn06 | Class D | 5 | 10th March 2008 09:03 AM |
| Complete noob to all of this, help to my feet? | jesuslovesyou | Subwoofers | 5 | 4th September 2007 01:51 PM |
