#151 | |
Art: I may have to try that. Maybe the problem isn't as big as i first thought. I'm just not used to looking at speakers without grills when they get some juice. Well, sounds like a little experiment can confirm whether i'm just overprotective or not
#152 | |
Sorry for the delay ,I will post the cone dimension measurements later . |
#153 |
I decided to unfold the MTH30 to be able to compare the design with the Tham 12
![]() The MTH30 is bigger and the horn is wider but the path is much shorter S2 to S4 (Or S3) is 157.6cm compared with 172.3 for the Tham 12 The MTH fold is very linear and the only comment I have is the 199MM panel could be increased by 11mm to gain a little path length and linearity. In its basic form, without any adjustment for the driver, the sim in Hornresp could be done with only 3 sections. Screen grab of MTH30 unfold, and PDF comparing with the Tham12 Lots of extra dimensions for Akabak fans! Regards Xoc1 |
#154 | |
#155 |
Hi ghettosynth,
How about comparing: Post #27: Hornresp for MTH30 Post #89: Hornresp for THAM12 ? Then use the Wizard in Hornresp to see what dimensional change produces what result? Regards,
Oliver |
#157 | |
I'm sorry if I wasn't clear. Indeed, I've been playing with these designs for some time. Many of these variables are not independent and it is often not clear what in the system is changing when a parameter changes. I was really trying to get a bigger picture here. |
#158 | |
Based on experience, do you guys think that these boxes would produce similar results? Which box would you build? I read elsewhere that they could not be compared because the MTH has much larger volume? I get that the horn length relates to the tuning of the box, but it's still not clear to me how, holding horn length constant, how an increase or decrease in volume will affect the system. |
#159 | |
One cone dimension measurement coming up ![]() cone dim.jpg |
#160 |
I'd go for something in-between
. The FR curves suggest that the THAM12 is too small and the MTH30 is too large for the driver you modelled.
www.diysubwoofers.org |
| Running Home audio in my car. Complete Noob. | leochevalier91 | Car Audio | 16 | 18th December 2011 10:53 PM |
| Advice for/questions from a complete noob to amplifier DIY. | jaistanley | Class D | 10 | 18th November 2010 08:32 PM |
| complete noob question | beauistheman | Chip Amps | 19 | 10th August 2009 06:37 PM |
| Complete noob needs help | tstarn06 | Class D | 5 | 10th March 2008 09:03 AM |
| Complete noob to all of this, help to my feet? | jesuslovesyou | Subwoofers | 5 | 4th September 2007 01:51 PM |
