MTH30 Questions : Complete Noob!
Old 6th February 2013, 05:17 PM   #141
tb46 is offline tb46  United States
Hi kornnylike,
For a correct drawing I'll need the shape and depth of the cone. I'll attach a drawing w/ question marks. Also, please verify the overall dimensions in the drawing.
Oliver
Old 6th February 2013, 05:31 PM   #142
Chaps is offline Chaps  Denmark
Originally Posted by ghettosynth View Post
They look great. Do you have any measurements, or even simply comments regarding their performance? Also, if it's not too much trouble, I'd love to know what drivers, handles, and connectors you used as well as any particular issues that you might have had during construction?
I love the stacking feet, I presume that they have been routed so that they can be stacked in either dimension?
I'd love to see more pictures, either build shots, or side/rear shots, if you have them.
At the risk of pushing my luck, have you weighed them?
As I say, they look great, you appear to know what you're doing and it would be great to hear field reports from people who have actually used them. I've seen plenty of discussion about MTH30 builds, and, of course, this thread has a lot of discussion of the THAM12 design, but I've seen very little about actual THAM12 builds.
tnx,
gs
Hi GS.
As i haven't really had the time to play with them (thet finished yesterday) i have no measurements, but i have an initial impression after a few minutes of listening. They sound very clean, punchy and precise. I heard them next to a commercial 2x15" reflex cab (NOVA Visio VS215) and there was a huge difference in sound quality. The THAMs just walked all over the reflex cab with lovely sounding bass.
After this coming weekend i can comment some more on the SPL the THAMs can produce.
I had them crossed at 45Hz with a 24dB BW slope and i think i might raise that to 50Hz in hope of getting rid of some cone movement. All in all i look forward to play around with different settings and i will of course post my findings.
Mine er loaded with PD.12SB30 drivers. All accessories can be found at Adam Hall. The rubber feat is 38x10. The handles is the smallest model they have (can't remember exact size). The pole mount is with 20mm thread. Connectors is standard round 4-pole neutrik.
Construction wise, to fit the handle i just moved the upper brace to the side. The pole mount is just mounted far enough back to not interfear with the internal panels.
All-in-all not anything speciel. BUT if you are to build with PD.12SB30 you have to make the cabinet a few mm. wider to make the driver fit!
You are right. There have been routed for feet on both sides and top/bottom. The way they are on the pic is only intended for transportation, as i want to use them laying on there sides.
Some building pics:
Assembly
Assembly
Almost finished with the first cab
After routing of the edges + test mounting of the drivers
After 2 layers of paint. They could need some more though
Mounting all fittings and drivers
Done and quick test
EDIT: Just had them on the bathroom weight. It says 28kg each.
Old 6th February 2013, 07:48 PM   #143
ghettosynth is offline ghettosynth
Originally Posted by Chaps View Post
Hi GS.
Some building pics:
Thanks so much, for a beginner who doesn't want to either make simple mistakes, or conversely, worry about the wrong things, your post was super helpful.
Old 6th February 2013, 08:04 PM   #144
weltersys is offline weltersys  United States
weltersys's Avatar
Assuming the Tham 12 simulation is correct, (which you could confirm with sine wave testing) the excursion minima is around 51 Hz.
With a BW24 at 45 Hz the drivers are more likely running out of excursion in the 60-80Hz range, only way to reduce that is turn down the volume.
Old 6th February 2013, 08:17 PM   #145
Can only say that you are absolutely correct according to that simulation.
I will have to do some proper testing to find out how much power they can take without exceeding xmax.
As i am looking at the drivers moving it seems to me, that they sometimes move quiet alot, but is there an easy way to see/measure how much the cone is actually moving?
Old 6th February 2013, 08:39 PM   #146
So in 60-80hz it seems that the graph suggests that the output is less than 0.5mm, is that supposed to be 0.5cm? The driver has an xmax of 7mm so 0.5 cm would make more sense?
Perhaps I misunderstand something else?
Old 6th February 2013, 08:49 PM   #147
weltersys's Avatar
Simply put a white dot on the cone, run sine waves through the cone, and compare the dot's peak to peak movement at various frequencies with a ruler.
When approaching Xmax (half of the peak to peak distance), make sure to not run sine waves for more than a few seconds, and leave at least double the time between tests as the individual tests take.
If you don't want the detail, use pink noise. If you raise the HP to 50 Hz and the cone is still over Xmax, you know the problem area is above Fb.
Old 6th February 2013, 09:08 PM   #148
Djim is offline Djim  Netherlands
Hi Chaps,
When and where did you buy your PD drivers? For accuracy I have to know if you have an old or a new version.
Old 6th February 2013, 09:17 PM   #149
weltersys's Avatar
It is only driven at 2.83 volts, the figures are in mm, the comma is substituted for a period.
The driver runs out of excursion before the voice coil burns .
Old 6th February 2013, 10:54 PM   #150
Ok, of course, that's what I missed.
MTH30 Questions : Complete Noob!Hide this!Advertise here!
Running Home audio in my car. Complete Noob. leochevalier91 Car Audio 16 18th December 2011 10:53 PM
Advice for/questions from a complete noob to amplifier DIY. jaistanley Class D 10 18th November 2010 08:32 PM
complete noob question beauistheman Chip Amps 19 10th August 2009 06:37 PM
Complete noob needs help tstarn06 Class D 5 10th March 2008 09:03 AM
Complete noob to all of this, help to my feet? jesuslovesyou Subwoofers 5 4th September 2007 01:51 PM
