MTH30 Questions : Complete Noob! - Page 10 - diyAudio
Old 30th January 2013, 01:50 AM   #91
Originally Posted by Xoc1 View Post
The Tham 12 is tiny.
On Martinsons blog the Tham12 is shown with a sim of over 88 litres
This is despite the actual internal volume being 74.3 litres without any bracing or driver!
The path length is also shorter than shown on the blog.
With the PD 12SB 30 I would expect 98db at 75hz in a 2pi sim
Have not unfolded the MTH30 yet!
Xoc1
Ah, that might explain the difference. I haven't seen any measurements of actual THAM12 builds, only variations on the design similar to what I've discussed.
Old 30th January 2013, 02:13 AM   #92
Djim is offline Djim  Netherlands
On Martinsons blog the Tham12 is shown with a sim of over 88 litres. This is despite the actual internal volume being 74.3 litres without any bracing or driver! The path length is also shorter than shown on the blog.
With the PD 12SB 30 I would expect 98db at 75hz in a 2pi sim.
Hi Xoc1,
I agree with your model. Based on measurements of the Tham12 I found on another forum I made a re-model. The measurement was done with a 18Sound 12LW1400 driver which I used to re-model it.
If you use the input of the old version of the PD.12SB30:
And for the newer version of the PD.12SB30;
Old 30th January 2013, 03:13 AM   #93
Originally Posted by tb46 View Post
Would the cone correction (throat correction) be applicable to the Tham series of THs?
Hi Oliver,
Now I have re-modelled the Tham12 I can show, by decreasing S2 (Cone-Volume-Correction), how it improves the dip.
For those (some Swedish members ) who assume that cone-volume-correction adds significant compression to the system, please take a good look at the pressure and velocity models! Like the model shows, cone-volume-correction has no significant effect on pressure while it only increases velocity! In my view, this also shows why Danley 'gets away' with his V-stub without adding too much compression.
Old 30th January 2013, 06:23 AM   #94
Chaps is offline Chaps  Denmark
Xoc1
As i am not (yet) i hornresp user, can you explain to me why you are simming with Eg: 2.35 opposed to Eg: 2.83? Isn't this the applied voltage?
Old 30th January 2013, 06:55 AM   #95
Hi Chaps,
Perhaps Xoc1 wanted 1 watt into a nominal load impedance of 5.49 ohms (the value specified for Re) rather than into the standard 8 ohms.
Kind regards,
David
www.hornresp.net
Old 30th January 2013, 07:13 AM   #96
Originally Posted by David McBean View Post
Hi Chaps,
Kind regards,
David
Ahh i see.
Maybe i have to read a bit about the difference af nominal/minimum impedance and Re.
Just thought people always simmed with 2.83V on a (nominal) 8 ohm speaker.
Will the sim be more "real-world" when using Re?
Old 30th January 2013, 08:09 AM   #97
Hi Chaps,
All it means is that for whatever reason, the simulation has been done using a constant input voltage of 2.35 volts rather than 2.83 volts. The SPL and diaphragm displacement values will be marginally less than those achieved using 2.83 volts, but this is the only impact on the results. Xoc1 may perhaps care to comment on the reason for using 2.35 volts rather than the generally accepted standard of 2.83 volts (which delivers 1 watt into an 8 ohm load).
Kind regards,
David
www.hornresp.net
Old 30th January 2013, 11:16 AM   #98
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Hi Chaps,
Kind regards,
David
Technically this is what is known as a late night session cockup
Regards Xoc1
Old 30th January 2013, 11:32 AM   #99
Originally Posted by Djim View Post
Hi Oliver,
That sim'd FR suggests that the mouth isn't large enough.
www.diysubwoofers.org
Old 30th January 2013, 11:42 AM   #100
Regards Xoc1
That makes good sense to me
Guessing that will make it go around 1.5dB up from the approx. 98dBs (from your sim)
Running Home audio in my car. Complete Noob. leochevalier91 Car Audio 16 18th December 2011 11:53 PM
Advice for/questions from a complete noob to amplifier DIY. jaistanley Class D 10 18th November 2010 09:32 PM
complete noob question beauistheman Chip Amps 19 10th August 2009 07:37 PM
Complete noob needs help tstarn06 Class D 5 10th March 2008 10:03 AM
Complete noob to all of this, help to my feet? jesuslovesyou Subwoofers 5 4th September 2007 02:51 PM
Copyright 1999-2017 diyAudio
