Please Critique My Idea
Old 25th January 2013, 08:23 PM   #21
epa is offline epa  Netherlands
you are answering my question with a question.
i'm not pro or con a ppsl.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 25th January 2013, 08:59 PM   #22
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by weltersys
If they are "push pull" (which cancels even order harmonic distortion, leaving the non-musical odd order distortion)
Originally Posted by Inductor View Post
It's that a problem of the push-pull isobarics? Can you link to some notes or paper on that issue (isobaric distortions types). Regards.
I don't regard reducing even order harmonic distortion as a "problem", but when pushed hard, (as in the case of many professional applications) the result can be less musical sounding than if the even order distortion was there to mask the odd sounding odd order harmonics.
In general I am not a fan of isobaric loading, though it can be useful if space is limited and budget is not.
My opinions on PP in more detail are here:
Push Pull vs Normal Distortion Compared
Art
Old 25th January 2013, 09:22 PM   #23
weltersys's Avatar
Originally Posted by sreten View Post
Show me a design where whatever volume you use
for the slot is not best used internally, or any good
sub design where a slot would have any useful effect.
rgds, sreten.
Sreten,
A plenum can actually reduce the cabinet volume given up by the baffle and grille depth needed when front mounting long throw speakers.
My old L4 design from 1987 and L2 from 1992 used a large "V" plenum slot.
Kicked like it was horn loaded, but had the extension BR gave.
After the success of the L4, I noticed over the years that slot load designs became increasingly popular.
The difference between a plenum, slot, or a stubby horn is semantic, but there are dozens of commercial designs and hundreds of DIY using various slots, these are just a few popular current commercial examples:
Adamson T-21
Community's VLF218
D&B B2
EAWs SB1000 and SP 2001,
Fulcrum Acoustic's 2x15" 2x18" 2 x21"
Renkus-Heinz PN21SUB
All of the designers decided that the use of the plenum outweighed the internal volume displaced.
One primary advantage of a plenum slot is it allows the driver front panel to be smaller than front loading would allow.
The plenum creates an acoustic bandpass, reducing all harmonic distortion.
If one subscribes to a desire for reducing even order harmonic distortion, mounting the pair of speakers "push pull" in a plenum is more effective to that end than front mounting the speakers.
The plenum provides some mass loading, responsible for a subjective increase in "punch".
Opposing speakers cancel vibrational forces, subs using plenums won't "walk" like front loaded speakers do.
There are probably many other positive attributes for using plenum mounts, all of which need to be weighed against the amount (if any) of cabinet internal volume loss.
Art Welter
Old 25th January 2013, 09:33 PM   #24
R.I.P.
As far as I'm concerned it has nothing to do with domestic AV subwoofers.
Any technical argument that says it does I'll contest as long as said
argument is one, not this device has one, is used for AV, so must work.
rgds, sreten.
Old 25th January 2013, 10:36 PM   #25
weltersys's Avatar
rgds, sreten.
Sreten,
One can argue that "subs" with very high rate of sales (Bose) also have nothing to do with with domestic AV subwoofers, but that is a different argument.
I gave 6 technical points describing why plenums can be useful both in some domestic and large scale applications.
Care to contest them one by one, or are you more happy just dismissing them wholesale ?
Art
Please Critique My IdeaHide this!Advertise here!
Layout critique Neutrality Solid State 36 22nd June 2011 07:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 09:18 AM
Critique my first design bigwill Tubes / Valves 11 3rd June 2007 12:30 PM
Critique my circuit? 5u4 Tubes / Valves 8 15th May 2006 02:08 AM
Design critique MWP Digital Source 6 22nd August 2004 05:20 AM
Copyright ©1999-2017 diyAudio
