Old 17th January 2013, 03:51 PM   #1
katana2112's Avatar
Default dcs450-4 in a 12x24x48 box
I tried simming it with AJ s box design software and ended up with 2 6" vents.....sim says 22" long...is that EACH or 22" total between 2 ports? I want to use it for dual duty, It will fit in my trunk but with legs I can also use it in the living room....Any thoughts?
Aggressively Passive
Old 17th January 2013, 04:02 PM   #2
Each port would be 22" long.
I think you must have a big trunk.
Old 17th January 2013, 05:28 PM   #3
katana2112's Avatar
It will fit perfect without feet,with them I would fold down the rear seat. Im port placement be OK on the end facing into the cabin?
Old 17th January 2013, 05:34 PM   #4
The wavelength of the port output will be many times the length of your car unless it is a stretch limo, port position will make little difference.
Old 19th January 2013, 05:24 PM   #5
4 foot cabinet fits in your car?
Old 19th January 2013, 05:37 PM   #6
katana2112's Avatar
2006 Hyundai sonata......Big trunk
Old 19th January 2013, 05:41 PM   #7
katana2112's Avatar
Could 2 of those woofers workin the box? I dont know enough yet to model it.
Thanks,
Dave
Two Dayton Audio DCS450-4 18" Subs PE: 295-475 MyNameIsJake Swap Meet 4 18th November 2012 02:54 AM
In Bass reflex box (vented)-If I make smaller box than what consequences will I have? eliaselias_0 Multi-Way 6 3rd January 2011 03:49 PM
Aperiodic box for B200. Vent size and box shape? ChuckT Full Range 11 15th October 2006 07:29 AM
Want to re-box several si t amps in one box. How do I hook up to one power supply? ExJxC Class D 7 22nd September 2005 09:27 PM
High voltage umbilical and connectors / 1 box for PSU 1 box for amplifier in kit88 PTSOUNDLAB Tubes / Valves 30 10th September 2003 07:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
