#11 |
bjorno,
This project you posted looks awesome. I hope OP takes advantage of it with a few pictures and final observations.
#12 | |
. If someone move the simulation into Sketchup or a Cad: program,the unclear ? dimensioning of the Port system would be much more clearer....Here are more on the same subject: A lot more numbers to dig into ![]() b
#13 |
bjorno,
I learn so much from your posts. Things like several mistakes and bad assumptions that I made in building the first Lab 12 OD_ML_TL. I was wondering why the stuffing material was so hard to fluff up enough to fill almost the entire line , andI have finally come to fully understand port end effect corrections, and it is not the same as when modelling intakes on 2 stroke engines as I was thinking it may be. Thank you, Dave....Hmmm?
<---My Transmission Lines from a prior life Top one Tweeter...Bottom one definitely a Sub |
#14 |
Thank you for the help, the project is underway! I will post with results and pics.
Now I need to find a new receiver... Sound quality for music is my most important requirement with easy calibration and room correction. Good Home theatre audio quality is a bonus but I am willing to separate HT entirely or sacrifice this for best music sound. I mostly listen to rock (elvis - classic - punk - metal - alt/indy rock) and ALL types of electronic. First a few things I would like: - I dont want a receiver that will colour or brighten sound, natural the way the music was recorded would be ideal. - Very good EQ to balance and correct sound within a room as needed easily. - Cool running. - With HT I want to make sure that I dont have to crank volume to hear voices in movies and then sounds effects are too loud (current old low end sony sucks for this). Also HT should have THX. - Best Value for the $, my budget is $600. - 4ohm stability. My subwoofer is two ID 10" 4ohm subs in custom box with 300watt bash plate amp so this would not require 4ohm stability. I have nice car audio ID CSX64 co ac speakers that I would like to build boxes for home. I would like to be able to use high end home audio speakers at 8 ohm in the future as money allows. I am currently looking at the Onkyo 709, is this the best option in my budget? Any suggestions on good receivers, and where to buy, would be appreciated. Thanks |
#15 | |
Are you sure of this?! |
#16 |
No not really, home audio is all new to me so I am looking for some suggestions. As mentioned my previous experience is onlu with an IASCA winning sound quality vehicle.
I was thinking of using the 709 for now, my sub has a plate amp, and adding amps for other speakers using the pre outs as I get the $. Unless there are better suggestions. Any assistance is appreciated as I only wish to buy each poece once for a long time. Thanks |
| My first stomp box build | revolver944 | Instruments and Amps | 4 | 26th May 2011 04:32 AM |
| How To Build A Home Sub Box | clapster | Subwoofers | 6 | 24th January 2007 03:49 PM |
| Box Build | Staticjeep | Car Audio | 9 | 20th August 2006 09:22 PM |
| how did you build your box | jpark | Car Audio | 1 | 7th April 2006 11:10 AM |
| Need help to build box for this SUB | dipdip123 | Subwoofers | 3 | 19th February 2005 01:56 AM |
