Old 12th January 2013, 06:54 PM   #1
ryuji is offline ryuji  United States
Default enclosure for custom driver
this will be used for home theater type uses, playing games, and listening to some music. I value sound quality over boomyness/volume. preferably good frequency response at low volume
I was planning on making the box small-ish as practical as space is at an unfortunate premium at my living arrangements around 2 feet in any one direction would be ideal but i can go a bit larger
* Piston Diameter = 266.7 mm
* f(s)= 29.61 Hz
* R(e)= 2.52 Ohms
* Z(max)= 42.07 Ohms
* Q(ms)= 3.676
* Q(es)= 0.674
* Q(ts)= 0.570
* V(as)= 39.600 liters (1.399 cubic feet)
* L(e)= 1.33 mH
* n(0)= 0.15 %
* SPL= 94.73 1W/1m
* M(ms)= 319.70 grams
* C(ms)= 0.09 mm/N
* BL= 23.99
*Xmax= 25.4 mm
Other info:
LMS coil technology 3" copper clad aluminum voice coil, single wind @ 2.5ohms, aluminum cone from a GZ plutonium sub, high roll rubber surround 12 spoke 12" basket, custom motor made from a 3 x .750" Y32 ferrite stack, TC9 T yoke with a full copper shorting ring pressed over the poll, TC7 top plate @ .500" thick (spec for LMS coil). Max power on that sub is around 600wrms but closer to 1000wrms
I think im on the right track? I am completely new to enclosure design
Old 12th January 2013, 07:10 PM   #2
The ported response looks fine, as long as it is within the driver's excursion and power limits, and you are satisfied that the output is adequate with the power available to drive the sub.
Old 12th January 2013, 07:35 PM   #3
chris661's Avatar
Run the same thing in WinISD Pro: you get a lot more charts to play with.
I think you may struggle to fit a big enough port in the enclosure.
Old 12th January 2013, 08:01 PM   #4
Inductor's Avatar
The BR looks bad on paper and my gut tells me that the closed one is better.
Now, my EBP software recommendation is sealed (43).
Edit: anyway if used as a sub with it's own amp (BR) and not as a "stereo" the thing is different. More SPL on the lower end.
What's the name of the driver, if it makes any difference...
...Max power on that sub is around 600wrms but closer to 1000wrms
WTF?
Old 12th January 2013, 09:00 PM   #5
the driver doesnt have any official name as it was custom made for me by a friend. those t/s specs were measured using some kind of measurement tool/software. i think he was giving a max power estimate. regardless at time of building and now still its irrelevant as im going to operate it with a 200w amp(an independant amp). im after signal quality at volumes that are acceptable to the neighbors not dB
only reference to a model is TC9/7/3hp-12-s2.5
sealed enclosure works very well for me as im nowhere near a carpenter, simple is good =)
Old 12th January 2013, 10:13 PM   #6
A duct is not very difficult to put in, and can be sealed off with a block of hard foam (or a pair of socks )if desired.
The difference of around 8 dB at 20 Hz would mean the BR would sound more than twice as loud as the sealed enclosure down that low, where your ears are far less sensitive.
It would require about 1000 watts (and an 8 dB EQ boost) for the sealed enclosure to achieve the same level as the BR using 200 watts.
Old 12th January 2013, 10:48 PM   #7
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI: Check the T/S parameters...
b
Old 13th January 2013, 02:07 AM   #8
Inductor's Avatar
"The legendary TC9"... must be one of these ?!
Old 13th January 2013, 02:19 AM   #9
looks a lot like those
ill have to find out whats up with the t/s specs unless its simple to figure out. could have been a transcription error of some kind
its a little dirty as my life got busy the last few months and it was sitting around in a semi open box
all that ferrite makes it awfully heavy for its size thats for sure --
he sent me a spare spider and voice coil i could take pictures of or measure if needed/wanted but i doubt that'd be useful at all
Old 13th January 2013, 03:24 PM   #10
Ok, these are the ones for your sub, the ones you posted are of a mockup sub I was building you, some how they got pasted to 1 sheet.
single 2.5 ohm coil, the test was with a 4 ohm with same specs
Qts = 0.43
Qes = 0.46
Qms = 6.7
Fs = 28
Res = 3.96
Ls = 4.7
Lp = 7.7
Rp = 5.1
Dia = 250
Vas = 39
mms = 280
cms = 115
bl = 20.5
SplSens = 84.5
time to play around and produce new graphs to look at i guess
Help with custom car enclosure Xyberz Car Audio 4 23rd December 2008 12:31 PM
What features or sizes do you want in a custom enclosure? BoilermakerFan Parts 6 23rd June 2008 02:20 PM
Custom sub enclosure for trade Christof Subwoofers 3 25th January 2004 05:38 PM
Custom Enclosure for 03 WRX mc91183 Car Audio 18 5th August 2003 06:51 AM
Custom Enclosure in UK Rarkov Everything Else 2 28th July 2003 01:11 PM
Copyright ©1999-2013 diyAudio
