enclosure for custom driver
Old 14th January 2013, 12:19 AM   #11
Inductor is offline Inductor  Portugal
Inductor's Avatar
Originally Posted by ryuji View Post
single 2.5 ohm coil, the test was with a 4 ohm with same specs...
What do you mean?!
Is it a DVC Subwoofer with a 2+2 ohm dual voicecoil connected in series or a single voice coil
Piston Diameter = 266.7 mm
Probably this is the measure of the cone (Surround/Surround) of a 12". Do you have a 10" or a 12"
Dia = 250
Is this a 10" DVC Subwoofer with 10.10"/25.65cm Overall Outside Diameter
How much for the Sd parameter then.
Old 14th January 2013, 12:30 AM   #12
ryuji is offline ryuji  United States
largest diameter is about 12.5 inches, the 250mm is the cone
all i know is its 2.5 ohm nominal as it stands now. the earlier specs are out the window that was incorrect data he accidentally sent me
sorry for the confusion, i was rather confused myself
Old 14th January 2013, 03:43 PM   #13
GM is offline GM  United States
GM's Avatar
Specs calculated from basic T/S. Notice that the other specs line up close enough except BL, which if 20.5 would drop Qes, Qts quite a bit.
Xmax?
Le@ 1 kHz?
Pe [Rms, transient peak]?
GM
File Type: gif LMS custom driver specs [ryuji] T-S.gif (13.9 KB, 45 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 14th January 2013, 04:16 PM   #14
Inductor's Avatar
the driver doesnt have any official name as it was custom made for me by a friend.
Originally Posted by Inductor View Post
"The legendary TC9"... must be one of these ?!
largest diameter is about 12.5 inches, the 250mm is the cone...
TC Sounds LMS-R 12" DVC Subwoofer
Your driver must be this one then (same specs).
Old 14th January 2013, 04:52 PM   #15
that does in fact match up near perfectly, the yoke looks the same, but the part that holds the diaphragm and the magnets look different.
Old 14th January 2013, 04:52 PM   #16
GM's Avatar
If true, then the new set of specs published here are probably bogus since the custom has a 2.5 ohm coil.
GM
Old 15th January 2013, 06:18 AM   #17
Inductor's Avatar
Other info:
LMS coil technology 3" copper clad aluminum voice coil, single wind @ 2.5ohms, aluminum cone from a GZ plutonium sub, high roll rubber surround 12 spoke 12" basket, custom motor made from a 3 x .750" Y32 ferrite stack, TC9 T yoke with a full copper shorting ring pressed over the poll, TC7 top plate @ .500" thick (spec for LMS coil). Max power on that sub is around 600wrms but closer to 1000wrms
Very likely the "frankenstein" driver got an heavier cone (319.70 grams) vs. 280g, only one coil of the LMS (TC Sounds LMS-R 12" DVC Subwoofer) (2.52 Ohms) vs. 3.96 ohms. The basket is a "TC9" type (TC Sounds Epic 12" DVC Subwoofer)
How much did you pay?
LMS coil technology 3" copper clad aluminum voice coil, single wind @ 2.5ohms, aluminum cone from a GZ plutonium sub, (spec for LMS coil)
TC7 drivers - 12" 2567
What is a TC9 ?
Old 15th January 2013, 07:21 AM   #18
Inductor's Avatar
TC9 drivers - 12" 2568
Old 15th January 2013, 02:47 PM   #19
I didnt pay anything for the driver, it was a gift. He built it after i explained i wanted SQ not dB. the spare coil has a hourglass shape to it and only two leads but i think thats what makes it lms?
Old 15th January 2013, 03:14 PM   #20
GM's Avatar
Bottom line is that without measuring its specs, any design will be a crap shoot.
GM
enclosure for custom driverHide this!Advertise here!
Help with custom car enclosure Xyberz Car Audio 4 23rd December 2008 12:31 PM
What features or sizes do you want in a custom enclosure? BoilermakerFan Parts 6 23rd June 2008 02:20 PM
Custom sub enclosure for trade Christof Subwoofers 3 25th January 2004 05:38 PM
Custom Enclosure for 03 WRX mc91183 Car Audio 18 5th August 2003 06:51 AM
Custom Enclosure in UK Rarkov Everything Else 2 28th July 2003 01:11 PM
Copyright ©1999-2017 diyAudio
