pro driver sound with only 15 watts?
Old 14th January 2013, 05:24 PM   #31
panduro is offline panduro  Denmark
Hi Bitsmasher,
that would make it a high power sub with an monstros 25watt amp.
with that little power, even 5watt extra should to make a differens.
i could do 2 drivers, as long as they will fit on a panel this size hXwXd 62x62x32cm.
best regards
panduro
Old 14th January 2013, 07:56 PM   #32
OscarS is offline OscarS  United States
Originally Posted by panduro View Post
Beyma power 12 freq looks very good. 102db 25W/4ohm f3 27hz with a very nice curve. But must admit that i have never heard a nice sounding heavy coned car driver that sounded very good without a **** load of power stuffed up its erhhhmm terminals .
It's a vicious circle that is a direct result of Hoffman's Iron Law. This is where a fundamental understanding of inter-related T/S parameters truly does help.
many heavy coned car driver's have a very stiff suspension. This directly affects the required (small) enclosure size to attain an achieveable frequency response curve. But too stiff and the free air resonance goes too high (Fs). The only way to bring it back down is with: mass. ...and then the low Vas (due to the low compliance (stiff suspension) due to the small-box requirements of most car drivers) directly affects efficiency, and thus power sensitivity. All other things equal, the less compliant a speaker is, the lower the efficiency---so then what counteracts low efficiency: a lot of (cheap) power stuffed up it's terminals. No way around Hoffman's iron law.
Since you don't have a lot of power (15W), and you want it to play decently low, you absolutely must give up the idea of a (relatively) small enclosure for a particular driver IF you want to exploit it's "reference" sensitivity. Starting out with lots of cone surface area will only benefit you if you build the enclosure to suit. Otherwise you may as well start out with less surface area in order to exploit the sensitivity of a smaller diameter driver.
Stuffing two (large) driver's in your required dimensions will not do anything for sensitivity because you will likely be crippling each one due to the lack of enclosure volume airspace. Obviously if they are a smaller pair of drivers that can use your given airspace, you can exploit their sensitivity, but albeit at a lower starting point. In the end you end up with the same darn thing. It's mother nature's way of telling you "there is no free lunch".
Just another two cents...
Old 14th January 2013, 10:01 PM   #33
CCU is offline CCU  Denmark
Send a message via MSN to CCU
If you want to try out the Fane 15-600lf in real life. i have 4 of them that i'm not using currently.
Old 15th January 2013, 07:36 AM   #34
Inductor is offline Inductor  Portugal
Inductor's Avatar
Have you been using them OB ? (Nice for a BR/VB = 213 L)
Old 15th January 2013, 03:35 PM   #35
I you meant what I am using the driver for... I'm using them for multiple things.
Experimenting with OB and in the summer i'm using them in backloaded horns for my outdoor/festival speaker system
Old 16th January 2013, 01:03 PM   #36
thanks for all the answers,
keep the 2 cents advice coming as im saving for a full dollar
that was a good explanation, even i got that
hmm think im make the sub with a jbl le120h1 from my ht. figured out that i can do a 120L enclosure, which means i can get it flat to just below 30 with god sensitivity.
wheather or not i go with the 15w or decide to go with a bit more still remain to be seen.
Hi CCU, thanks for the generous offer, but it seems that it needs a very large enclosure to get the desired curve.
but itd love to come by to check out your system- ill bring the beer
best regards
panduro
Old 18th January 2013, 08:43 PM   #37
SpirosZ is offline SpirosZ  Greece
You can use two 4ohm drivers in a push pull configuration and cut box vol in half.
Old 16th February 2013, 02:26 PM   #38
papasteack is offline papasteack  France
http://www.ciare.com/pdf/catalogo/CW258ND.PDF has a 21L vas...try simulations...Or a http://www.ciare.com/pdf/catalogo/PW258ND.PDF if you prefer 8ohm...?
Old 16th February 2013, 07:23 PM   #39
26 liters tapped horn...1x10". 30-180hz @ 100db back to a wall @12w 4ohm...Need a high pass @ 35 hz. So no prob with the 30hz spike...can/need to be adjusted more fine. It's just to show. 19 ms group delay @ 30hz... 3mm cone displacement...far from the 9mm xmax... it go to 180 hz so it can be well crossed...the speaker curves seems good. Seems interesting ??
pro driver sound with only 15 watts?Hide this!Advertise here!
WTB: eminence kappa pro or omega pro 15 inch murphythecat8 Swap Meet 0 22nd November 2012 03:46 PM
Hammond 1609 for 15 Watts guitar amp? Cassiel Instruments and Amps 4 31st October 2009 06:44 PM
Selenium WPU1509-SLF 15" Pro Sound Driver gpsmithii Swap Meet 0 29th December 2007 01:00 PM
15 watts loud enough? ThSpeakerDude88 Tubes / Valves 31 28th December 2006 08:56 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
