Old 11th January 2013, 07:51 PM   #21
chris661's Avatar
Originally Posted by iamthefly View Post
Thanks about the ply. its only about £60 a sheet after tax. they also do an oak veneered ply which is cheaper that i might use. Cross bracing, gotcha.
I'm confused, I've checked the infinity in 3 different sources and its usable frequency only goes down to 23Hz, is it that is just close enough or is there something I'm missing? While we're on the subject can a human being destinguish between 20Hz and 23Hz?
Cheers
All speakers have a set of parameters describing their operation, called Thiele-Small Parameters, after the chaps that figured them out.
The parameters allow simulations (via a computer program - WinISD Pro is a useful one) of any given driver in any given cabinet.
http://uk.infinitysystems.com/tl_fil...260W_PI_EN.pdf
Here they are.
Have a look on t'interweb for what they all mean.
The 23Hz cutoff frequency (quoted by the manufacturer) is irrelevant - don't worry about it. The T/S parameters are what's needed to tell you what its going to do in your cabinet.
Chris
Old 12th January 2013, 07:04 AM   #22
Ahh thanks. I've ordered a book. I'll look at that software right now. I had thought I'd be able to get away without doing the graphs and such, just build a box of the recommended size (most drivers seem to say 'designed to work in enclosures 45L-70L'), shove in a driver that specifies 20Hz and be done. Ah, we'll. I'm not against learning the math and software, just hoped I wouldn't need to. However my obsessive personality has snagged on this project so I have to see it through. I won't even get to play it that often because the darn thing will wake/terrify the kids. They'll thank me when they are old enough to play X-box games through it 'pew pew'.
I've also gone off TL it'd need to be about 80m long to tune it to 20 Hz. Thats a big box. sealed or vented will need to do.
Old 12th January 2013, 07:15 AM   #23
OscarS is offline OscarS  United States
This article should be of use to you, having an EE degree
Engineering is the Best: January 2008
Old 12th January 2013, 07:42 AM   #24
ßart West-VL.'s Avatar
Thanks! I've been looking for an article with T&S explanations.
I hope to, not just knowing what it means but actually understanding it.
more!more!
Old 12th January 2013, 02:05 PM   #25
Thanks, will read it through when time allows
Old 12th January 2013, 02:31 PM   #26
Einric is offline Einric  United States
Have a look at the Legend of El Pipe-O'.
It is a subwoofer design that needs a room that is "Long On Space" and is suitable for 12"+ subwoofers.
It uses the transmission line design for loading the sub.
If I had a LARGE living room you bet I'd have one.
Old 12th January 2013, 07:50 PM   #27
more!more!
This is also a good paper:
http://files.engineering.com/downloa...com_101027.doc
Old 13th January 2013, 03:08 AM   #28
tvrgeek is offline tvrgeek  United States
Just a basic reality check. Good clean subwoofer for $200? Sorry. About the cheapest I would call tolerable would be maybe a Dayton RS with an O-Audio plate. By the time you are done, you probably still have $350 in it.
Every car woofer I tested had terrible levels of distortion compared to what I can live with in my home. I still like my old Peerless XLSS 12's for music. Go read what Siegfried Linkwitz has to say about subs.
Old 13th January 2013, 05:55 AM   #29
GM is offline GM  United States
GM's Avatar
Originally Posted by chris661 View Post
GM, thanks for the comparison. I am curious, though - why would the JBL need the bigger vent?
Surely the extra 1mm of Xmax isn't enough.
If they'll both hit 20Hz, I'd take the JBL for the cast frame - not much risk of bending it while tightening screws.
You're welcome!
It's a function of Sd, Fb, Xmax: TA Speaker Topics: Vent FAQ's
Sorry, but that's about the most ridiculous criteria for choosing a driver I've ever heard.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th January 2013, 09:27 AM   #30
chris661's Avatar
Originally Posted by GM View Post
You're welcome!
GM
I fail to see how my criteria is ridiculous: Two different drivers will achieve similar performance for the same price, but one has a cast frame, the other being stamped steel.
I've heard of people over-tightening drivers with stamped frames, resulting in misaligned voice coils. In order to avoid that, surely it makes sense to go for the cast frame driver?
Help me quick! A nooby question. nad Digital Source 1 30th March 2010 08:00 PM
Quick nooby questions weinstro Multi-Way 6 3rd October 2007 06:41 AM
Nooby speaker design questions weinstro Multi-Way 5 27th September 2007 11:11 PM
Hi, total nooby from Mexico Onix Introductions 7 30th August 2007 04:45 PM
new nooby in forum! adeline Introductions 2 9th May 2007 03:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
