Old 6th January 2013, 08:16 PM   #1
Default car subwoofer filter 48 db/octave
Hi could anyone please comment on the following circuit. Its an car subwoofer LP filter... tkx
http://static.diyaudio.com/forums/ga...a/1785/sch.png
Old 7th January 2013, 12:19 PM   #2
djk is offline djk
djk's Avatar
Too small to read.
Candidates for the Darwin Award should not read this author.
Old 7th January 2013, 12:40 PM   #3
Default LP
try this one... tkx
Old 7th January 2013, 10:27 PM   #4
Default Car LP Filter.... Version 2
any feedback wold be great ... tkx
Old 8th January 2013, 09:22 AM   #5
First: I’m unsure you are really need in doubled buffer for output.
Second. There will be strong crosstalk in input cable because of the link between input capacitors.
Third: There’s no necessity to duplicate op-amps for direct and reversed signals.
It would be better to use one amp for mixer and next amp as inverter.
To switch phase it is enough to connect the filter input before or after inverter.
Fourth:
It is good practice, to minimize THD and to get maximal noise rejection ,to have direct and inverted inputs loaded by symmetrical current.
So, some of grounded inputs should contain resistors and some of resistors should be corrected.
For example:U7. The equivalent resistance at inverting input is paralleled R17||R18 -5kOhm, then to provide doubled current for U7 and U8 the R15 and R16 must be 5 kOhm too.
Old 8th January 2013, 07:01 PM   #6
Default thx for the feedback
R15 & R16 ar a simulation of a 100K potentiometer because I couldn't find it in LTSpice... as for the input could you give me ani suggestion
is this better?
Old 8th January 2013, 08:55 PM   #7
Click the image to open in full size. better?
Old 8th January 2013, 10:16 PM   #8
Default version 3 LP filter 48 dB/octave
any feedback wold be greatly appreciated ... tkx
Old 8th January 2013, 10:21 PM   #9
May I ask what is the purpose of resistors R1 and R4?
Old 8th January 2013, 10:24 PM   #10
its just for simulating in LTSpice ... R1 and R4 are dummy-loads
Subwoofer Filter PCB with LFE sensing, EQ sections, 12/24 dB LR cutoff Mfly Group Buys 145 18th January 2013 09:07 PM
12 dB enough for subwoofer lowpass filter? JanErik Analog Line Level 0 2nd September 2010 08:41 AM
Use Octave/Matlab for filter generation? fb PC Based 2 21st January 2010 11:21 AM
Multi octave ribbon for a car Madmike2 Planars & Exotics 2 5th November 2007 06:21 PM
24 dB/Octave 2/3-Way Linkwitz DC on output after power cut Calebay Solid State 37 27th January 2006 06:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
