Jmlab SW-33A repair
Jmlab SW-33A repair
Old 30th December 2012, 09:11 AM   #1
Jonas83 is offline Jonas83  Sweden
Default Jmlab SW-33A repair
Hi all!
Searched for some time, hope this is no dupe!
Got this Jmlab sw-33a (12" focal sw) that needs alot of love!
One transistor blown (visualy), 1 15000uf cap vented and possibly more!
I have not been able to find any schematic or specs on sw element such as impedence, it measuers 6.7ohms and is a real pain to drive as my only amp around tripps when i raise vol, so i wounder is it really this heavy to drive, or is it busted? it is a impressive peice of element, so would not be supprised if it is heavy to drive.
The amp has been tempered with, previous owner probably done a cooling paste replacement and overlooked the plastic washers between heatsink and transistors causing a shortout trough the heatsink, leaving one transistor visualy blown and vented one of the big caps (elna lp5 15000uf/63v).
Starting out like this, pictures of the thing will popup as i work with it.
Old 2nd February 2013, 07:52 AM   #2
Very much later....
This is a "china board" and maybe crappy from start, anyhow i want to fix it since the sub is kind of nice.
Changed the output transistors, and have a coulpe of new 15mF caps waiting.
Checked all power/signal transistors and diodes (even zeners on my bench) but i still have a BIG problem.
It works whitout the filtercaps of course loads of hum). Now to my real problem, as to this everything looks good and measure well but when i try it with the caps on, nothing happens (bulb as ballast) except a nasty heat development making the heat sink varm. i am very sure of polarity of caps so thats not the problem. Could this be and effect of a halfly bad bridge rectifier giving halfwave rectification on negative and fullwave on positive or am i just stupid here?
Old 2nd February 2013, 08:55 PM   #3
Nope, rectifier would not be the problem and my previous theory of that was probably mumbo.
Did find the issue, owner before me (who killed it) abused the pcb so bad that the trace trough/over collector pin was left open in one direction. this did the trick of dumping a massive current from positive supply side and left a vented cap.
anyways it works now, doubt it, but hope this helps someone else.
Old 9th April 2014, 08:38 PM   #4
dragon64 is offline dragon64
Default 33A sub
Hi Jonas83
I own olso a 33A buy it last year.
My board look not simulair mayb later version.
My project starts in nov-2013.
Starting th sound check! the low bass end was not very good.
First making a plan.
-Recap power circuit. 2 powercabs yes 15000uf 63v
-Extra wood braces inside cabinet
-New damping material
-Replace the cabinet.wood finisch
Greatings from Holland
Jmlab SW-33A repairHide this!Advertise here!
focal jmlab subwoofer redrooster Subwoofers 3 22nd February 2011 02:10 AM
JMLab Profil7 upgrade dynapos Multi-Way 5 23rd September 2007 03:49 PM
JMLab Chorus 715 JacekPlacek Multi-Way 0 4th September 2006 06:06 AM
Modifying JMLab 715 Megabox Multi-Way 1 22nd December 2003 01:06 PM
JMlab Speakers Harmon Multi-Way 8 5th July 2002 07:19 AM
