Variable Port Lengths/Diameters? Like a pipe organ... - Page 2 - diyAudio
Old 29th December 2012, 10:33 PM   #11
@sreten: I think I understand your point. I do wonder, though, I thought that multiple ports worked like parallel resistors/inductors (roughly). That is, the pressure change caused by the motion of the driver will find equalization by all available paths based on the instantaneous resistance of the paths. That would mean that with proper balancing of the diameters and lengths of the different ports, they should respond to the driver differently under different frequencies and volumes. Make sense?
Old 29th December 2012, 11:04 PM   #12
Basically wrong. They are much more like series LCR's in parallel.
Consequently the highest tuned port dominates the low rolloff, by
providing the lowest impedance to ground at all low frequencies
preventing any other lower tuned port having any useful effect.
rgds, sreten.
Old 29th December 2012, 11:23 PM   #13
@sreten: Thanks. Exactly what I needed to know.
Just for others who might be curious: https://en.wikipedia.org/wiki/RLC_circuit
Old 30th August 2013, 12:25 PM   #14
Thank you for the explanation Sreten!
Old 31st August 2013, 08:18 PM   #15
Originally Posted by sreten View Post
Hi, Its been done, by the[...] marketing who don't [CARE ABOUT] the physics.
Take a speaker tuned to 50Hz by one port and 25Hz by a much bigger port.
The 50Hz port depressurises the cabinet below 50Hz so the 25Hz port has
next to no effect...[/QUOTE]
I'd be curious to hear your comments about David Weem's design. In case you're not familiar, that's where you have 3 ports all the same size. One vents from the main chamber to outside, one from the main chamber to a second chamber, one from the second chamber to outside (was trying to find an image on the internet, but no luck).
I simply can't wrap my head around what will happen, if it really works or not. If I had more time ha ha I should build one and test it...
Old 31st August 2013, 09:11 PM   #16
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
if you tune two ports just a small bit different, I think it broadens the ressonance peak
but that may be all there is to it
maybe it also have influence on possible upper port peak(midrange)
different port diameters in a single subwoofer box? ThyDntWntMusic Subwoofers 17 27th September 2011 03:35 PM
Port lengths for 2-chamber 2-port bandpass Circlotron Subwoofers 12 15th February 2011 01:09 AM
Looking for jazz bass and pipe organ toenail Music 8 16th January 2011 06:56 PM
Port lengths: which measurement? rajivs Multi-Way 11 30th July 2009 05:55 PM
Pipe Organ sub workout Circlotron Music 3 10th April 2007 01:01 PM
Copyright 1999-2017 diyAudio
