Horn flare - Page 2 - diyAudio
Old 28th December 2012, 06:15 AM   #11
Hi Dusty,
I was surprised that the very lowest end response was just as good, ever so slightly better, than the exponential.
Look carefully at the profiles in my earlier post - notice how starting from the throat, the "circular" horn profile (blue trace) increases at a slightly slower rate than the exponential horn profile (red trace) for about the first 28 cm of the horn. This is the reason for the marginally better predicted low frequency response.
So throat, mouth and axial dimension would determine the radius of the circle.
Not in the more general case - given only S1, S2 and L12, it then becomes necessary to also specify a radius. As mentioned previously, the radius effectively determines the amount of curvature in the flare.
So far, it seems like you would be able to model the "circular" horns fairly accurately in hornresp using the exponential setting. I wonder however if the responses would differ in comparison at much higher or lower frequencies? Wink, wink.
I'm not promising anything, but I will look at the possibility of adding the "circular" horn profile to Hornresp. I will let you know if the profile is ultimately included.
I am looking for Beranek's book online, does it talk extensively about horns?
There is one chapter devoted specifically to horn loudspeakers, but much of the information in other chapters is also directly applicable to horns. Beranek's book complements Olson's text very nicely.
Kind regards,
David
www.hornresp.net
Old 20th January 2013, 07:15 AM   #12
Hi Dusty,
Hornresp can now model radius (circular arc) horns. See Hornresp for further details.
Kind regards,
David
www.hornresp.net
Old 21st January 2013, 04:07 AM   #13
Thank you David! I know I and hopefully many others will put it to good use.
Dusty
Old 21st January 2013, 06:35 AM   #14
Hi Dusty,
You're welcome. Thanks for prompting me to add the radius horn option to Hornresp :-).
Kind regards,
David
www.hornresp.net
Casting Experiment: Elliptical Horn Flare MJL21193 Construction Tips 96 8th June 2012 02:55 AM
Modifying horn flare/cutting a horn's mouth Andy_P Multi-Way 10 5th May 2010 03:25 PM
Front Horn flare diameter questions Bill poster Full Range 21 19th March 2010 04:10 PM
How to make a horn flare? Bill poster Full Range 0 11th June 2008 10:14 AM
Combination flare on front (Azura) horn limono Multi-Way 18 26th December 2007 06:26 PM
Copyright 1999-2017 diyAudio
