Horn grouping question. - diyAudio
Old 25th December 2012, 05:48 PM   #1
Default Horn grouping question.
So I am having trouble making heads or tails of horn grouping given the plethora of differing opinions on horn loading. From what it seems to me you can truncate the length and mouth size of a horn (while keeping the flare rate) and group the horns to the needed mouth size for a given frequency to get equivalent performance to a full size horn, of course assuming a similar acoustic loading environment. Am I missing something here? What am I not taking into consideration? Thanks all.
Old 25th December 2012, 07:31 PM   #2
weltersys's Avatar
You can use multiple horns to make up for mouth size, but path length determines Fc.
You can not truncate the length without raising the horn cutoff frequency.
Old 25th December 2012, 07:47 PM   #3
more10 is offline more10  Sweden
If you design a horn for corner use (0,5 pi), u can use two of these for wall placement (1 pi), four horns for floor placement (2 pi) and eight for suspended placement (4 pi).
Old 26th December 2012, 06:18 AM   #4
Hi Art,
Just to clarify - it is perhaps worth making the distinction between the actual theoretical flare cutoff frequency of a horn, and the resultant practical low frequency response rolloff.
Horn length can be truncated without raising the cutoff frequency provided that the flare rate remains unchanged. For example, the following three exponential horns have the same throat areas and flare rates but different lengths - in each case, the cutoff frequency stays constant at 100 hertz.
S1 = 10.00
S2 = 2397.32
L12 = 150.00
F12 = 100.00
S1 = 10.00
S2 = 385.91
L12 = 100.00
F12 = 100.00
S1 = 10.00
S2 = 62.12
L12 = 50.00
F12 = 100.00
In other words, to be strictly correct it is actually flare rate that determines the horn cutoff frequency, not length.
As the horn is shortened however, the increasing mismatch at the mouth causes the ripples in the throat acoustical impedance to become larger, and the shorter length means that the ripples will be further apart in frequency. Both these things conspire to make the resultant response roll off at a higher frequency, even though the theoretical cutoff frequency of the horn has not changed.
Kind regards,
David
www.hornresp.net
Old 26th December 2012, 03:06 PM   #5
So... Theoretically, one would be able to group 6 horns with an L12 of 100 and S2 of 385 and get nearly the same effective mouth area and response as the longer, larger horn?
What got me thinking about all this was looking at Olson's paper that had response charts for different lengths of horns with the same flare cutoff and throat size and the responses were relatively similar, not taking into account the major impedance fluctuations presumably caused by small mouth sizes.
Thanks again David.
Old 27th December 2012, 06:53 AM   #6
Hi dustman96,
I'm not sure that your observation above is strictly correct, but it seems you may get reasonably close - the black trace in the attached chart shows the Hornresp predicted power response for six 100 cm horns connected in a 2S x 3P array radiating into 2Pi space. The gray trace shows the response for a single 150 cm horn radiating into 2Pi space.
Kind regards,
David
www.hornresp.net
Old 27th December 2012, 11:21 PM   #7
Hey David,
Thanks for running that through Hornresp and sharing. Pretty interesting. I wonder if the slightly smaller mouth area of the 6 horns as opposed to the long one makes the difference. I bet in the real world the coupling wouldn't be perfect so response might suffer slightly. I don't want to ask too much of you but if you have the time would you mind throwing just a single foreshortened 100cm horn onto that graph as well?
I don't know about you, but I find horns fascinating!
Dusty
Old 28th December 2012, 05:12 AM   #8
Hi Dusty,
For you, just this once only :-). My very strong preference is for people to spend a little time learning how to use Hornresp so that they can try these things for themselves - it is by far the best way to learn, and to understand what is going on.
That said - the black trace in the attached chart shows the Hornresp predicted power response for a single 100 cm horn radiating into 2Pi space. The gray trace shows the response for a single 150 cm horn, also radiating into 2Pi space. As expected, the response of the 100 cm horn is more "peaky" than that of the 150 cm horn because of the smaller mouth size and the resultant poorer mouth acoustical loading. Even though both horns have the same flare rate, and hence the same theoretical cutoff frequency, the longer horn has slightly better low-frequency extension for the reasons outlined in my earlier post to Art (weltersys).
Kind regards,
David
www.hornresp.net
Old 29th December 2012, 02:48 PM   #9
djk is offline djk
djk's Avatar
Candidates for the Darwin Award should not read this author.
Old 29th December 2012, 03:55 PM   #10
Originally Posted by David McBean View Post
...My very strong preference is for people to spend a little time learning how to use Hornresp so that they can try these things for themselves - it is by far the best way to learn, and to understand what is going on...
You are correct.
However, we don't all have Hornresp. And I'm sure a lot of others, like me, really don't have a need to mess with it.
Nevertheless, although I'm not building horns, I'm really curious to see this kind of stuff --> thanks for running the sims and posting them.
Horn question? Arizona Dan Full Range 1 23rd March 2011 11:43 AM
Tapped horn question soundhead Subwoofers 1 22nd June 2010 05:25 PM
Zaph has another driver grouping up! ScottG Multi-Way 30 29th June 2006 11:23 PM
Car horn question fr0st Subwoofers 20 2nd February 2005 08:03 PM
Horn question lordvader Multi-Way 1 30th March 2002 02:44 PM
Copyright 1999-2017 diyAudio
