BNS Intelligent SDS-Sub MKll schematic wanted
Old 24th December 2012, 09:35 AM   #1
JohanH is offline JohanH  Netherlands
Default BNS Intelligent SDS-Sub MKll schematic wanted for repair
Hello all,
I bought a defective BNS Intelligent SDS-Sub MKll.
It's an active subwoofer
Haven't received it yet so hopefully just a blown fuse
There doesn't seem to be much info available on the later BNS speakers so I'm asking here for info and hopefully a schematic of this subwoofer.
Thanks in advance,
Johan
Old 29th December 2012, 05:29 PM   #2
It arrived today.
Unfortunately the fuse is ok.
There's a fairly loud hum when the sub is switched on, the on LED lights shortly and then goes dark again.
So good thing the amp seems to be working.
There are 2 PCBs inside: one amp (TDA7294) with rectifier and caps and one with crossover, standby circuits and inputs (3 quad opamps TL084 and a SA572 compandor). Not sure what a compandor does in a sub....
I resoldered some suspicious joints and tapped the PCBs to sort of check for loose joints. There is + and - 37V across the PS caps.
Next I will try so see if amp and crossover function seperately.
And take some pics.
The components inside surprised me somewhat; metalfilm and 1% resistors so hopefully I will be able to resurrect the thing.
Johan
Old 29th December 2012, 07:05 PM   #3
Speaker is Peerless 850384
PCBs are marked UnisubAmp and UnisubF2
Old 21st April 2014, 01:47 PM   #4
Finally got around to working some more on this.
Ended up replacing the TDA7294.
Sound distorts occasionally and hardly works when using the high power inputs. RCA works better; but still distortion.
So back to the workbench for more detective work...
Old 22nd April 2014, 09:34 AM   #5
And finally succes.
Distortion was caused by a bad connection at the speaker..
Old 21st October 2015, 09:52 PM   #6
rafaeldatarock is offline rafaeldatarock  Netherlands
Great to see you managed to fix it! It's a great sub, i've been using it for years.
I still don't know what the ACC switch is for though, all it seems to do is make the volume way louder.
Does anybody know what the 'ACC' switch was originally meant for?
BNS Intelligent SDS-Sub MKll schematic wantedHide this!Advertise here!
Basic questions about the MKll TA2020 LaurensBER Class D 5 11th January 2012 09:37 PM
Type of Plug for MKll Tripath TA2024 board a95sonoma Class D 4 5th January 2012 06:26 PM
Coral Flat 6 mkll monitors skvuppla Full Range 6 18th April 2011 01:42 PM
Creek 4330 Mkll. Mint condition. tweakk Swap Meet 2 6th March 2011 07:07 PM
Wanted Mordaunt-short MSW20 Schematic Wanted simon dart Subwoofers 0 22nd May 2009 09:19 AM
Copyright ©1999-2017 diyAudio
