T-TQWT for Peerless 835017 T-TQWT for Peerless 835017 - diyAudio
Old 24th December 2012, 07:43 AM   #1
3GGG is offline 3GGG  Australia
Default T-TQWT for Peerless 835017
Is anyone happy to help simulate a T-TQWT sub for me.
I am looking to use 2 of the drivers in each enclosure, similar to the build here…
Fiddling with Hornresp - Peerless 831759
I would like a single fold and height can be up to 2000mm, extension need to go to 110Hz where the Fane 8m kicks in.
I will attempt to model myself when i can get access to a PC, damn Mac's :0
Old 24th December 2012, 08:47 AM   #2
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I wanted to offer some help with the sub, but it seems you need help with your computer/excuse more.
Bootcamp
Parallels
VMWare Fusion
Manual boot partition selection (option key)
Get yourself a WinXP Pro SP2 COA and CD then you are good to go.
Dan
Old 24th December 2012, 11:26 AM   #3
Not keen on bootcamp, I usually use my work pc for hornresp but on holidays.
Old 24th December 2012, 11:27 AM   #4
NEO Dan's Avatar
VPN+RDP
Dan
Old 24th December 2012, 11:50 AM   #5
NEO Dan's Avatar
Version 2.1 is FREE, it's on the lower right side...
Remote Desktop Connection Client for Mac | Office For Mac
Good FREE VPN client
tunnelblick - OpenVPN GUI for Mac OS X - Google Project Hosting
And at the workplace if it's not huge you can setup a proper security box using the FREE version of the SOPHOS UTM
Sophos UTM Essential Firewall - Sophos products - Sophos
Home version also FREE
Sophos UTM Home Edition - Sophos products - Sophos
Dan
Old 24th December 2012, 12:52 PM   #6
I have managed to get an old laptop going. Early simulations are looking peaky at either end.
Old 24th December 2012, 03:00 PM   #7
GM is offline GM  United States
GM's Avatar
Vas is way too low for Fs, Qts to extend this driver to its ~110 Hz high mass corner without either using a too small terminus and/or heavily stuffing it unless loaded with at least 4/cab, so a better candidate for TH or TQWT loading with the latter being my preference [dual driver TQWT file]:
GM
File Type: txt p835017d.txt (432 Bytes, 21 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th December 2012, 03:53 PM   #8
bender460 is offline bender460  United States
Try two of these in that same box. Dayton Audio DCS255-4.. That is my plan anyways.
Old 25th December 2012, 02:55 AM   #9
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
How about an 8 foot (2133.6mm) x 11" (279.4mm) x 7.27" (184.66mm) 33hz tapped quarter wave pipe (TQWP)? With 0.75"(19mm) stock, a single fold enclosure would be 49.5" (1257.3mm) tall x 12.5" (317.5mm) wide x 16.79" (426.27mm) deep. No angles! 100 watts @ 8 ohms, safe to 27hz.
T-TQWT for Peerless 835017Hide this!Advertise here!
Midrange comparison Peerless 830870 VS Peerless NE123W-08 diypass Multi-Way 3 30th May 2012 08:13 PM
Adequate Crossover frequency of Peerless 835017? Peter Huang Subwoofers 13 3rd October 2011 06:28 AM
Peerless xxls12 835017 Asdonk Subwoofers 2 2nd September 2011 12:41 PM
peerless 12 inch 835017 fs measurements tucsonaudio Subwoofers 0 1st December 2010 09:16 PM
ML-TQWT with Peerless HDS exclusive? tubee Multi-Way 0 18th June 2007 08:00 AM
Copyright ©1999-2017 diyAudio
