Adding internal resonantor to back loaded horn? - diyAudio
Old 22nd December 2012, 10:10 AM   #1
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
Default Adding internal resonantor to back loaded horn?
I have recently tested the vintage Klinger 12" horn. With the right driver, in my case Beyma G320, I get a output of 35-130 Hz +/- 3dB measured at the mouth opening using Omnimic. However there is a large peak at 85-90 Hz that I would like to knock down 4-5 dB. Would a internal helmholz resonator do it? How critical is the placement of IHR in the horn path? The ones I have seen have the IHR at the driver or at least pretty close to the start of the pipe.
Photobucket is currently down so I can not add any images, however, if you take a look at Doctor Boar; DIY loudspeakers and HiFi for pictures of the horn, drawings, driver and measured curves.
Old 22nd December 2012, 06:32 PM   #2
tb46 is offline tb46  United States
Hi DrBoar,
One article that comes to mind is by E. Jakulis, TQWT Design Example: "...This article on the effects of Helmholtz resonators in TQWT design by E. Jakulis was brought about by an active discussion with Filippo Punzo." You might want to google it.
At the bottom of the Reply to Thread page is a Manage Attachments box, click on that, and you can add pictures to your Post.
Oliver
Old 23rd December 2012, 11:03 AM   #3
DrBoar's Avatar
Here is the drawing of the horn and the response of the Beyma Driver
Old 23rd December 2012, 01:19 PM   #4
djk is offline djk
djk's Avatar
1/4W stubs in the Danley DTS-20.
Try about 3" dia x 36" with some polyfill inside.
http://www.danleysoundlabs.com/danle...t-ISO-View.jpg
Candidates for the Darwin Award should not read this author.
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 09:32 PM
Is this a back-loaded horn? zcables Multi-Way 3 17th September 2012 05:48 PM
Combination of Back-loaded Horn and Fron loaded horn?! ARIYAHOOR Full Range 26 1st June 2012 10:20 PM
back loaded horn nige838 Full Range 4 21st October 2010 01:33 PM
Back Loaded Horn Bending Tyimo Multi-Way 15 17th April 2005 06:04 PM
Copyright 1999-2017 diyAudio
