hello. built 2 boxes for 4 woofers. they are split in the middle with 40mm mdf.
size is 45liter. i know it wont be optimal to put other elements in them. figured i could use a dsp. to make it a little better. but the question is wich of these would be best? 835017 - Peerless XXLS Xpanded Extra Long Stroke 12 inch subwoofer - Europe Audio 830669 - Peerless SLS-315 coated paper cone AL shorting ring in magnet system - Europe Audio the boxes are closed... |
#2 |
Hi razakiel666,
The XXLS is the better driver for your sealed boxes. May I recommend you look into Hornresp, it makes it so easy to take a quick look at something like this. Regards,
Oliver |
#3 |
checked curves and the xxls will be used instead of sls. will start with 2 xxls an buy the last ones later.
have to sls from other boxes. that a friend made. they were wrongly buildt and not 100sealed and som minor faults. never could get them to sound good. |
| Expensive speakers with dirt cheap DIY-available drivers? | uDIYguy | Everything Else | 5 | 11th November 2012 04:32 PM |
| I built an expensive computer. It is unstable and has display artifacts.HELP!(vids) | thadman | The Lounge | 58 | 10th September 2010 04:21 AM |
| DC modules fot DHT amps....too expensive to buy pre-built, why not DIY them? | jmillerdoc | Tubes / Valves | 27 | 4th December 2009 06:03 PM |
| box replacement for powered speakers | tilroh | Multi-Way | 1 | 12th May 2008 02:58 AM |
| FS: Subwoofer Box for 12" Speakers | 2skys1imit3 | Swap Meet | 0 | 19th June 2007 06:29 PM |
| Page generated in 0.50380 seconds (100.00% PHP - 0% MySQL) with 10 queries |
