Klipsch RW10D keeps blowing fuses
Old 16th December 2012, 01:11 PM   #1
baboo52 is offline baboo52
Default Klipsch RW10D keeps blowing fuses
I have a Klipsch RW10D that keeps blowing fuses when I try to power up and I am looking for suggestions on what component(s) I should replace.
Old 16th December 2012, 01:18 PM   #2
Mooly's Avatar
Would have to see the circuit really, but favourite (if it uses one) would be a monolithic output chip such as an LM3886 that has failed.
As always a few detailed and careful measurents will reveal the trouble... all the evidence will be there
Old 16th December 2012, 01:47 PM   #3
Thanks Mooly for your reply to my woes. I am a newbie at this and do not posses the equipment to test the components. I am looking to find a suggestion for a component assembly that I may acquire to remedy my malady.
Old 16th December 2012, 01:55 PM   #4
Mooly's Avatar
You would have to open it up and see what type of output stage it uses. Probably a "chip", and something like the LM3886 as mentioned. There won't be any "assembly" you can just swap. Its a case of unsoldering and removing the faulty part/s and replacing with new.
If you have a multimeter and can identify the basic parts in the unit then we might have a chance
You have to be confident using a meter and in your soldering abilities.
Old 17th December 2012, 12:09 PM   #5
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Default Bash amplifier?
I think that particular model uses a Bash amplifier... very hard (if not impossible) to get schematics for it... sorry...
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 17th December 2012, 01:47 PM   #6
Do you know if a replacement for the bash is readily available and would the unit be identified if I open the cabinet?
Klipsch RW10D keeps blowing fusesHide this!Advertise here!
Keep Blowing Fuses Whiting Tubes / Valves 9 11th September 2008 09:44 PM
Why are these fuses blowing Darin P-B Solid State 41 30th May 2005 10:56 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
Copyright ©1999-2017 diyAudio
