Please validate TH subwoofer design
Old 10th December 2012, 07:31 AM   #1
wxn is offline wxn  Lithuania
wxn's Avatar
Default Please validate TH subwoofer design
Hi everyone, I have a nice woofer laying around (salvaged from a fried Tannoy TS8 sub) that I would love to put to use. The TS parameters are measured using added mass method (pic). WinISD believes that this driver will hit 30hz in a 40l reflex box but then after fiddling with HornResp I managed to get a response I like (pic), which intrigued me as horns have a nice reputation.
Can someone more qualified inspect this horn and point out any possible flaws and/or its fesibility compared to BR? Perhaps it could be optimized in terms of size and/or performance? My goals are <~50l volume and working band 30-80hz or so
Thanks in advance,
K.
Code:
ID=29.00
Ang=2.0 x Pi
Eg=2.83
Rg=0.00
Fta=-0.22
S1=128.00
S2=152.00
Con=20.90
F12=0.00
S2=152.00
S3=192.00
Con=278.20
F23=0.00
S3=192.00
S4=188.00
Con=20.90
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=176.00
Bl=7.50
Cms=3.86e-04
Rms=2.44
Mmd=39.00
Le=0.90
Re=3.20
TH=1
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lpt=0.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=5.0
Comment=TS8 BH
Nothing is as simple as it seems
Old 10th December 2012, 10:35 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Default Tannoy and Audes 75W104-8 subs
Thanks in advance,
K.
Hi K,
Have a look at this:
b
PS: FYI,Added a Scandinavian more potent sub suggestion using IMO great drivers from another nearby Baltic Country.
Old 10th December 2012, 10:49 AM   #3
wxn's Avatar
My God that was quick, thanks a lot for this eye opener! This tqwt to be in a completely different league at almost half the volume... Any tips for the actual folding/implementation?
Regarding the other driver, it does seem very impressive but I guess it will have to wait for a bigger listening room and more tolerant neighbors
P.S. How do you put all the graphs together so quickly and tidily?
Old 10th December 2012, 11:52 AM   #4
You know 'Practice makes perfect' 99% is just cut and paste..For the moment I think you should browse this forum for folding tips, there are quite a few.
I posted the other suggestion in order to put 'Baltic' driver manufacturers on the DIY-Mapp.
I understand your concerns regarding the need of a larger room and worries of what neighbor would say if this sub is cranked up above 100 dB.
b
Old 10th December 2012, 12:07 PM   #5
wxn's Avatar
Yes, thank you very much. Just one last question - Hornresp seems to be very fussy about few cm changes to the length of the last segment. I assume this is the distance from voice coil to the mouth opening (of S4 area) that is positioned directly above the driver, as in the other example?
Old 10th December 2012, 12:18 PM   #6
Yes That's correct for the case of using 2 Drivers(If only one Driver too) it's the distance counted from the intersection between both, thus the terminating area shown in HR is moved and in order to make the enclosure to fit the drivers,a small additional length must be added to the baffle: this will increase the total length a bit.
b
Old 10th December 2012, 01:24 PM   #7
more10 is offline more10  Sweden
Check out Forsmans design. He added a fold to the generic Tham design. What is unique with these designs are that most angles are 90 and 45 degrees, only one mitred angle is difficult to do. Exremely easy designs to build.
If you want something folded only once, check out Volvotreters designs. I did a single folded design with front chamber that I am very happy with. It lacks some bracing though, its just a prototype.
Old 10th December 2012, 04:52 PM   #8
GM is offline GM  United States
GM's Avatar
A couple of more examples to play with in the wizard with a <50 L net Vb TH and offset driver TH [DTS] with a minor amount of peak power redistribution from the mids to the bass. 200 W peak/5 mm Xmax assumed.
Any idea what the actual/published Xmax is?
Rather than posting the design details, why not save them as a HR export txt file for others to easily import/install?
GM
File Type: txt ts8_th.txt (413 Bytes, 11 views)
File Type: txt ts8_dts.txt (414 Bytes, 6 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th December 2012, 05:54 AM   #9
wxn's Avatar
GM
I have no idea about the Xmax but 5mm seems reasonable, it's not a very long throw woofer. Thanks for the tip regarding txt files!
After playing some more with different designs, it seems that while tapped horns are somewhat inferior in performance to T-TQWT, they are also a lot less sensitive to minute parameter variations. I mean, just a couple cm on any dimension in bjorno's design leads to huge resonances. Unless of course HornResp is exagerating stuff. Any input on this is welcome, especially bjorno.
Thanks, very nice ideas indeed!
Old 11th December 2012, 07:28 AM   #10
GM's Avatar
And yet the sub was advertised as having a long throw woofer. Shame on Tannoy.
You're welcome!
Yes, for 2-2.5 octave 'sub' apps, a TH is a better bang/buck solution IMO, especially since it's more tolerant of driver specs variation.
HR doesn't exaggerate per se, it just doesn't account for any acoustical losses due to friction, construction material's damping, etc.. Build it out of thick, highly polished steel though and I imagine the measured response would be much closer, especially WRT HF 'ringing'.
GM
Please validate TH subwoofer designHide this!Advertise here!
subwoofer design gnanam Construction Tips 1 1st April 2011 03:01 PM
Help in subwoofer design. pmkierst Subwoofers 25 2nd February 2009 07:50 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
Aleph-X : could you validate ? GlouBou Pass Labs 3 30th August 2004 07:44 PM
