What is the best use of the Aurasound ns6-225-8a?
Old 9th December 2012, 08:46 PM   #1
sagamotto is offline sagamotto  Canada
Default What is the best use of the Aurasound ns6-225-8a?
Hello everyone, I am not sure where this thread is best placed, since this question is relate to LF reproduction so I though the nice folks in here might be interested in suggesting the right enclosure type.
Thks in advance.
Old 10th December 2012, 03:11 AM   #2
m R g S r is offline m R g S r  United States
The aurasound isn't much of a subwoofer......
I have, however, used them in multiple curt Campbell stentorians. They are decent for the $!
Old 10th December 2012, 03:39 AM   #3
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
How many do you have?
Dan
Old 10th December 2012, 01:07 PM   #4
Hello NEO Dan, this for the reply.
I have four ns6 and four T-amps. This is strictly going to be a two channel stereo low budget project. I will use two ns6 as in OB and two will be used as LF production. The apartment living room measure about 11'x10'. So space wise, it's a small room after the new couch are delivered. I noticed most enclosures currently proposed or suggested for the ns6 including bass reflex cab are tune to about the mid 40 or so. I haven't seen any other cab design that can further lower LF response. Do you by any chance encounter such cab as BHL or similar in design that can produce near the low 30hz range?
I enjoy music such as RnB, Jazz, movies soundtrack, chill lounge music, etc...
Old 11th December 2012, 08:28 AM   #5
DeonC is offline DeonC  South Africa
DeonC's Avatar
Hi guys
I was wondering- will these work in a tapped horn? Just curious.
Thanks,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 12th December 2012, 10:20 AM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by DeonC View Post
Hi guys
Thanks,
Deon
Hi Deon,
Here are suggestions that can be scaled down(the CSA:s) if using fewer drivers:
b
File Type: txt 4xNSQm.txt (473 Bytes, 18 views)
File Type: txt 4xNSTH.txt (471 Bytes, 12 views)
Old 12th December 2012, 10:38 AM   #7
DeonC's Avatar
Thanks,
Deon
Old 13th December 2012, 02:06 AM   #8
Hi Deon
Are you planning on using four ns6, cause I only plan on using one per channel in a slimmest cab possible tuck away in corner of my living. Could you may be kind enough to simplify from the simulation and post the dimensions require for one ns6?
Thks a million...
What is the best use of the Aurasound ns6-225-8a?Hide this!Advertise here!
Aura NS6-255-8A with Dayton DC28F tweets illnastyimpreza Multi-Way 45 6th July 2013 04:40 AM
Zobsky ponders the Aura NS6-255-8A zobsky Multi-Way 26 9th June 2012 04:39 AM
HT system with Aura NS6-255-8A kelv Full Range 1 28th November 2011 03:22 PM
Aurasound NS6 ... edinm Multi-Way 1 30th November 2010 03:16 AM
