diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Side mount dipol bass (http://www.diyaudio.com/forums/subwoofers/225266-side-mount-dipol-bass.html)
superlian 8th December 2012 06:22 PM
Whats the negative effect with this solution?
The positive is obvious, a slim apperance = WAF
mikeford 9th December 2012 02:51 AM
If you are talking about a true dipole radiator, putting it edge on to the listener means zero output at the listening position, its a null other than reflections in the room. I used an Enigma panel sub with my ESL63's for years, and while it was fantastic in the sweet spot of the listening chair, output suffered down to about average sound in the rest of the room.
Setup I used was to have my wife sit in the chair with a string held up to her nose and then place the edge of all three speakers on a arc equally distant from her with the Enigma in the middle.
sfdoddsy 9th December 2012 03:06 AM
You could do this with a slot-loaded system.
http://www.diyaudio.com/forums/multi...e-project.html
mikeford 9th December 2012 06:09 AM
1 Attachment(s)
Originally Posted by sfdoddsy (http://www.diyaudio.com/forums/showthread.php?p=3276861#post3276861)
Defeats the point of wanting them sideways doesn't it?
superlian 9th December 2012 07:37 AM
I was thinking about a design like Gradient Helsinki.
After my knowlegde it delivers bass but it require toe in and placement close to the front wall. I heard it on a hifi show in Norway and the bass was there.
My Q is if it is possible to get really god results with this solution or is it a huge compromise?
http://i.imgur.com/5Cf0m.jpg
sfdoddsy 9th December 2012 08:58 AM
Originally Posted by mikeford (http://www.diyaudio.com/forums/showthread.php?p=3276942#post3276942)
You don't need to have a baffle that wide. By folding it back and using active EQ it can be a lot smaller.
Here's an example:
http://www.diyaudio.com/forums/pass-...ml#post3234216
mikeford 9th December 2012 11:17 PM
Having been all the way down the dipole bass path, before spending a bunch you should first see if you like the character of the bass that is the end result. I found it different from my expectation, thinner even when level matched. I don't know why the sound is so different at the same level, maybe something to do with how room modes are excited, but it ultimately did not float my boat for many types of music where the artist intention is clearly fat bass as achieved with a good monopole subwoofer.
OTOH I do kind of prefer dipole mid bass, but overall bass I get from my Klipsch Forte' speakers seems close to ideal to my taste.
In that vein I would look at perhaps something of a 3 way design similar to the Nelsen Pass linked to, but using the folded dipole of the AMT with fewer drivers, crossed around 60 hz to a conventional monopole subwoofer. Something like Vocal range and top end driver, mid bass in the folded baffle, and low end sub. MTM might have very nice results.
Copyright 1999-2017 diyAudio
