Tapped or front loaded horn?
Old 9th December 2012, 06:41 PM   #11
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by Omholt View Post
From what I know also the Danley TH has the phase shift above 100 Hz. I don't think this is the case with Bill's FLH (Tuba HT). Are you sure this is correct?
The Gjallarhorn does have som peaks and resonances. Seems to be the case with all TH designs. Does this happen with FLH as well? I haven't seen any anechoic waterfalls of FLH.
Bill's hand drawn plots of in room response curves make it difficult to know what the cabinet's actual response is.
In general, a good FLH can approach a decade (20-200, 40-400 Hz) of useful smooth operation, while a TH is more limited to 2-3 octaves.
As you can see from the phase and frequency response of the DSL TH and their FLH with roughly the same low frequency cutoff, the TH actually has less phase shift than the FLH in the 20-200 Hz range.
Art
File Type: png Screen Shot 2012-12-09 at 12.31.10 PM.png (124.2 KB, 331 views)
Old 10th December 2012, 02:26 PM   #12
Omholt is offline Omholt  Norway
Omholt's Avatar
What dimensions are we talking about for a response from 20/25-200 Hz? Two units would be fine.
Wonder if that could be an option to traditional frontloaded box(es).
Old 13th December 2012, 12:30 PM   #13
weltersys's Avatar
Dimensions depend on the output level you desire.
Tapped or front loaded horn?Hide this!Advertise here!
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
2-way using front loaded horn and (sub)woofers Sella Multi-Way 7 26th September 2012 06:49 PM
Nautilus Front Loaded Horn tHEbLENNY Subwoofers 10 29th February 2012 04:06 PM
3 way front loaded horn help 3GGG Multi-Way 14 19th January 2011 01:57 PM
Front loaded horn concepts rabw Full Range 62 25th May 2006 12:17 AM
