diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Help with 8 inch Sun fire woofer based pushpull tapped horn please? (http://www.diyaudio.com/forums/subwoofers/224351-help-8-inch-sun-fire-woofer-based-pushpull-tapped-horn-please.html)
fatbattery 26th November 2012 11:50 AM
Help with 8 inch Sun fire woofer based tapped horn please?
Gday I just picked these up on impulse because prolly my medication was off or hopefully I was right in thinking these where too cheap to let go. Here they are. Sunfire Junior Subwoofer -Driver Only | eBay apparrently the seller has 2 not 4 available so ideas of a push pull tapped horn are out. He does have more 10' and 12's for 150 each which is getting to expensive for me. Though a 12 inch tapped horn does sound like a nice option using these sunfire type woofers.
I guess my biggest problem is that I will not be able to get factory specs. I thought maybe I can build a tapped horn. But I would need help with the design. I am also worried that they may even be motional feedback voice coils making them useless. I thought there might be a reason why I got them so cheap.
SUNFIRE: True Sub Super Junior - TS-SJ8
Do you think you good folks help me design a tapped horn for them? Are they even suitable? I will just make a pair of small sealed subs for PC use if they are not suitable for tapped horns.
fatbattery 26th November 2012 04:26 PM
Tapped Horns These 6.5 inch tagband I think folded horns what I would like to build. Just a slightly larger pair with hopfully a smidge more hiend. The low end is fine.
This seller does does have 10 and 12 inch drivers of the same contruction for 150 each.
DrDyna 26th November 2012 05:33 PM
The motion feedback shouldn't make them useless, as far as I know, most of them just use a piezo pickup mounted to the coil, or a small secondary coil. It should be a functional driver whether it's present or not.
The problem you're going to have is not having proper specs for the driver, which is what you're going to require to model a TH for it.
They do look a bit like Hi-Vi drivers though.
fatbattery 28th November 2012 01:52 PM
Originally Posted by DrDyna (http://www.diyaudio.com/forums/subwoofers/224351-help-8-inch-sun-fire-woofer-based-pushpull-tapped-horn-please-post3257704.html#post3257704)
Yea They Do. I couldn't get the 4 but I did get 2 or it looks like I will. Its a shame 4 would make a good ppsl cab too I would think. Perhaps I can just scale up volvo's TH design to take an 8 inch driver.
DrDyna 28th November 2012 02:33 PM
Originally Posted by fatbattery (http://www.diyaudio.com/forums/subwoofers/224351-help-8-inch-sun-fire-woofer-based-pushpull-tapped-horn-please-post3260796.html#post3260796)
You can try, but it's going to be trial and error without modelling it using proper specs.
pcb121055 2nd December 2012 02:09 AM
Just a thought, fatbattery... but I bought a WT3 from partsexpress for $99 which measures the parameters you need for a full design. No reason to guess. Weren't Sunfire (Carver) enclosure designs ELF?
norman bates 2nd December 2012 04:32 AM
you betcha
fatbattery 2nd December 2012 09:09 AM
I am Australia the shipping is huge but yea I get where your coming from.
fatbattery 2nd December 2012 09:11 AM
I know a guy that would test them for me. Then a design would be much easyer.
fatbattery 2nd December 2012 09:13 AM
Originally Posted by pcb121055 (http://www.diyaudio.com/forums/subwoofers/224351-help-8-inch-sun-fire-woofer-based-pushpull-tapped-horn-please-post3266423.html#post3266423)
Whats elf. Is it something that going to render my new speakers worthless?
Resources saved on this page: MySQL 18.75%
