Help with 8 inch Sun fire woofer based pushpull tapped horn please? - Page 2 - diyAudio
Old 2nd December 2012, 09:35 AM   #11
Location: In an old house on a hill needing repair looking over an old cemertry.
http://www.sunfire.com/whitepapers/S...Whitepaper.pdf lol I an not even going to open them. what a waste of money.
Old 2nd December 2012, 12:01 PM   #12
norman bates's Avatar
If I remember, they have multiple coils, like the earlier tc sounds.
That way you don't have a really long coil that can char the ends, or the coil not hanging in the magnet.
I'd heard a few of the 8's.
They went deep, but had no output in my mind.
But the box was small compared to a velodyne or definitive anyway.
I'd rather have multiple larger drivers barely moving (less distortion) than a small driver really flying back and forth. As you double the drivers, for the same volume excursion is halved, and distortion drops to 1/4.
Norman
Old 2nd December 2012, 03:28 PM   #13
Norman
Yea Norman It was a literal impulse buy. Found then in the last 6 minutes and they seemed cheap. And All so for a completely different approach. I have for the last 8 years been buying Richard Allan cg10's and a few 12's and a pair of cg10t's and 8t's.
But the cg10's I have been collecting for a array.I have lost count to be honest but I think I have 8 or maybe as many as 12. Ever body says I cant do any tapped horn but thought maybe I could do a tapped horn in push pull with the 10 or the 12's. I do have 4 of the 12's. They are lovely drivers for what they sell for used. But you do get a few duds off ebay I find. Here are some specs.
http://www.diyaudio.com/forums/attac...hard-allan.gif
Any potential here? I have the cg12 supers and normals.So maybe I have 6 12's
Old 3rd December 2012, 01:01 AM   #14
cg10's look fine for a TH.
I'm not so sure on the ultralow cg12's Qts.
Rear or front horn only for those, maybe a scoop.
If you run the numbers, they'd not have anything below 100hz in a sealed or ported.
Old 4th December 2012, 12:03 PM   #15
cg10 it is. I have the most of them.I can imagine the specs will be all over the place depending on the condition of spiders and surrounds. Thanks Norman
Old 5th December 2012, 07:32 AM   #16
np, just my opinion.
has anyone measured the sunfire woofer specs ?
I'm betting they are 16ohms or higher.
xmax is also a limiter.
~50 lb tapped horn, woofer under $100, high efficiency, low power? turbodawg Subwoofers 43 3rd December 2012 08:22 PM
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 12:01 PM
Cheap 10inch woofer in tapped horn? what would you do? ThyDntWntMusic Subwoofers 77 29th December 2011 11:38 PM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Copyright 1999-2017 diyAudio
