JBL 2226H 30 hz "horn" i built JBL 2226H 30 hz "horn" i built - Page 2 - diyAudio
Old 25th November 2012, 12:52 AM   #11
djlivex is offline djlivex  United States
Nice 4 cabs is that with the JBL or Faital Pro? Thanks!
Old 25th November 2012, 12:53 AM   #12
more10 is offline more10  Sweden
Thanks quinnling!
Should I assume that this design will work just as well for the JBL 2226J (16 ohm version). What is the dimension of the horn.
I cannot think of any reason 2226J would not work.
The dimesions are (HxDxW) 1196 x 936 x 494. Millimeters, you better get used to them :-). It is build with 18 mm Russian pine plywood. Next cab will be Swedish birch. You will need 2 sheets of 1220x2440 plywood for one cab.
Old 25th November 2012, 12:58 AM   #13
Faital Pro. I edited the post as well.
Old 25th November 2012, 01:06 AM   #14
more10 I think you have something here instead of going Tapped Horn.
Old 25th November 2012, 01:23 AM   #15
Actually I built a tapped horn for 2226. Not bad, but this one sounds better. The tapped horn sounds like a bass reflex on steroids. This one is cleaner and with much more energy in transients. It needs a big room.
This one is 50% bigger than the tapped horn. I can get as much spl from this horn as from the tapped horn, both tuned to 30 Hz.
This horn has a much better group delay than a tapped horn. It will behave very nicely outside of the crossover passband. You will need a digital delay in order to avoid comb filtering and to get full attack in transients.
Old 25th November 2012, 02:23 AM   #16
JoshK is offline JoshK  Canada
what a beauty!
Old 25th November 2012, 11:02 AM   #17
Originally Posted by JoshK View Post
what a beauty!
Thanks JoshK! But I would have been more flattered if you had called it a beast :-)
Old 25th November 2012, 08:10 PM   #18
epa is offline epa  Netherlands
great effort.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 25th November 2012, 08:26 PM   #19
Thanks epa!
Some more pics:
Old 25th November 2012, 09:52 PM   #20
Forsman is offline Forsman  Sweden
Forsman's Avatar
Hi
Cool project more10. Interesting contrast to all tapped horns beeing buildt.
/Fforsman
JBL 2226H 30 hz "horn" i builtHide this!Advertise here!
Celestion "Vintage 30" - Thiele Small Parameters wanted tiefbassuebertr Instruments and Amps 4 26th April 2012 03:30 PM
WTB: pair of JBL 2226H 15" woofers in excellent condition USA nicksgem10s Swap Meet 1 22nd April 2011 10:49 AM
WTB: JBL 2226G (pair) or blown 2226H/J and 1" compression drivers mikey7182 Swap Meet 1 6th March 2009 03:43 AM
JBL 2226H & 2426H cd/2370 horn combo in OB project..? JandG Multi-Way 6 1st December 2008 06:40 PM
jbl 2226h built :^) mikee12345 Multi-Way 14 24th July 2003 10:08 AM
Copyright ©1999-2017 diyAudio
