Thorn F1 - a learning experiance with Tapped Horn - Page 5 - diyAudio
Old 19th December 2012, 05:44 AM   #41
bitSmasher's Avatar
Fibreglassing over foam?
Old 19th December 2012, 02:55 PM   #42
tb46 is offline tb46  United States
Hi Forsman,
I like the styrofoam, easy to cut and shape. Old newspaper scraps (or Raufasertapete?) soaked in wallpaper paste should reinforce the surface just fine.
Oliver
Old 19th December 2012, 10:31 PM   #43
Forsman is offline Forsman  Sweden
Forsman's Avatar
Originally Posted by Djim View Post
Do I think what you think? In that case I'm not sure it will work. The density/stiffness of the styrofoam doesn't look 'experimental correction' enough....
I think you do.
And I have the same doubt about the stiffness of the material.
Originally Posted by mattlong8 View Post
Is it expanded or extruded polystyrene?
That I dont know. It is the cheapest sort made for insulation in construction works.
Could be an option but I am trying to find a simpler solution.
That might be the simpler solution I am looking for.
/Forsman
My blogg: DIY Open Source Hifi
Old 19th December 2012, 11:45 PM   #44
Originally Posted by Forsman View Post
Fiberglassing over Styrofoam ?
/Forsman
The usual Polyester resin used in "fiberglass" eats Styrofoam in seconds .
Boat and surfboard manufacturers use a special foam and epoxy, as did Sound Image for their speaker cabinets.
Very light, very stiff, very expensive .
Old 20th December 2012, 07:08 AM   #45
Forsman's Avatar
- Thanks for the warning.
That’s one reason to try a simpler way of creating a hard surface in an easier manner. I have thought of Divinycell and/or Epoxy but Epoxy is pretty toxic and thus a bit hard to work with. I occasionally use both Polystyrene and Epoxy to mend boats but for this trial I need a simple way of creating a cone volume compensation that is just good enough. Maybe it will suffice with Raufasertapete or even just a layer of paint, at least at low volume.
/Forsman
Old 20th December 2012, 07:21 AM   #46
Djim is offline Djim  Netherlands
...........try a simpler way of creating a hard surface........Epoxy..... toxic........hard to work with......... I need a simple way of creating a cone volume compensation.......
Maybe wood is an idea It's hard by itself, it takes 10 minutes to make 3 shapes and voilŠ........
Old 20th December 2012, 11:49 AM   #47
mattlong8's Avatar
Polystyrene and epoxy are compatible. Oh and extruded is stronger than expanded.
good luck.
-Matt
Old 25th February 2013, 06:21 PM   #48
Forsman's Avatar
I havenít been able to compensate for cone volume yet but I do have tried with some damping at 170 cm from S1 with promising result.
Measurement at mouth. Horn placed in a corner in a large open floor. 6 db/oct smoothing.
/Forsman
Old 4th March 2013, 09:42 PM   #49
/Forsman
So call me lazy, but what's the internal width of the cabinet? It looks like there's a lot of space on either side of the driver.
tnx,
gs
Old 4th March 2013, 10:59 PM   #50
Forsman's Avatar
Internal width is 42 cm / 16.54 in.
Kind regards
/Forsman
jbl gto804 tapped horn/ folded horn 2009thread1 Subwoofers 103 6th December 2015 07:26 PM
Horn Build using a tapped horn as a frame?? 3GGG Multi-Way 1 18th January 2012 12:52 AM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 07:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 06:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 01:51 AM
Copyright ©1999-2017 diyAudio
