Beyma SM-112/N Enclosure Help - Page 5 - diyAudio
Old 3rd December 2012, 02:15 PM   #41
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I think this is it
coming cutting plan will show if there minor errors
but I say this is the one
finished
do you like it ?
one last small correction is still possible( if needed due to space or whatever)
Old 3rd December 2012, 03:40 PM   #42
Vostro is offline Vostro  South Africa
Vostro's Avatar
Thanks so much, Im fine with the dimentions, so I dont need any changes
And yeah I like it, I'll finally have a home for my speaker
Old 3rd December 2012, 03:42 PM   #43
Vostro's Avatar
I can't say thanks enough for all the work you done.
Old 3rd December 2012, 03:47 PM   #44
lets just hope it will be a good one
cutting list coming, tomorrow(I hope)
Old 3rd December 2012, 04:53 PM   #45
cutting list added
feel free to play 'find an error'
I will try to come up with assembling plan
feel free to ask, any time
please keep us updated
good luck
Old 4th December 2012, 04:50 PM   #46
Vostro's Avatar
I've got a couple of questions,
Please check if I corrected the dimentions correctly
Other question is where should I place the breakout to speaker connector ?,
and should I add a passive x-over, I don't have one ?
Old 4th December 2012, 08:42 PM   #47
I'm glad to see you checked carefully
I left those slightly bigger intentionally
might be less once assembled
for one, the number 'depend' the summ of several other
and adding glue etc etc
anyway, its really bad if too small
better to a milllimeter to shave off when finishing
and, you may notice the number 580 is mutual for almost all cuts
means they are all equal and fits each other, because the saw havent been changed(maybe)
anywhere on the back is the usual place
why passive ?
are building one or two ?
and what are your other speakers ?
Old 4th December 2012, 08:51 PM   #48
sorry, some of the numbers and measurements are inside measurements
hould have been removed, or replaced
they were for myself only, to make the calculations easier
I fully understand if the right drawing have been confusing you
left one should be correct
and match the cutting list
but please just ask
better than making mistakes
Old 4th December 2012, 08:59 PM   #49
regarding the numbers you corrected
if you want them to match 100%, you may have to cut them after assembling the other ones
starting with front, ports and sides, with the bottom
then the back panel, and its bracing
finishing with the topplate
but just one tenth of a millimeter too small will look really bad
always make it two tenth bigger
for you it have been 2 millimeter instead of 2 tenths
Old 5th December 2012, 08:01 PM   #50
Vostro's Avatar
I agree, making them a tiny bit larger is a win win
Bass Reflex Enclosure for Beyma 10BR60 -_nando-_ Multi-Way 7 22nd June 2013 02:25 PM
Tqwt with Beyma BEYMA 12XA30/Nd simulation sladdbarn Multi-Way 11 18th May 2013 04:58 PM
15" Beyma SM-115N Giarsun Multi-Way 2 3rd October 2007 08:22 AM
Enclosure for Beyma 12CX - whats good? freddi Full Range 0 24th November 2006 05:12 PM
Beyma SM Series DarkOne Multi-Way 2 6th August 2006 07:57 PM
Copyright ©1999-2017 diyAudio
