Beyma SM-112/N Enclosure Help - Page 3 - diyAudio
Old 28th November 2012, 12:56 PM   #21
Vostro is offline Vostro  South Africa
Vostro's Avatar
thanks for all the time you spent on this
Old 28th November 2012, 03:31 PM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
well, the rest is simpler
maybe two more days
you do understand the drawing ?
and know how to do it, so far ?
oh, btw, your power amp...where ....?
probably best to put it in a seperate box
you can still place it on the outside backpanel
but if you want it, we could make a small closed room for it
Old 28th November 2012, 05:40 PM   #23
Vostro's Avatar
Thanks Ill have the amp in a seperate box,
Its classAB so its heatsinks are bigger, so Im busy making an enclosure for the subamp and my stereo amplifiers, the modules are already made, and transformers bought, Just the metal work to do.
Ill set the Iq lower depending if its audible, to make it run cooler
Old 28th November 2012, 07:13 PM   #24
ok
any preference to measurements, within the limits we have
I mean, would it best for you to have it wide and low, or better higher than wide, or just fairly equally sized ?
Old 28th November 2012, 10:13 PM   #25
and with side panels on
Old 29th November 2012, 05:57 AM   #26
lid on
Old 29th November 2012, 12:44 PM   #27
Default Interesting bracing scheme
Interesting idea of using external bracing, and the bracing being used to form ports.
Are the spaces between the top and bottom braces included in the internal volume of the box?
It is hard to tell from the drawing.
Just wondering if the passages that would exist, if they are included in internal volume, have a resonance that could be excited to create higher harmonic resonances.
The resonance would probably be very high compared to the passband of a sub, but I wonder if they could create single note "ting".
If they are included in internal volume, or even if not included, maybe some stuffing would benefit the performance in several ways.
Dave
Old 29th November 2012, 01:41 PM   #28
Originally Posted by Shadydave View Post
If they are included in internal volume....(edit)...... maybe some stuffing would benefit the performance in several ways.
yes, stuffing also
might consider them like volume buffers, when it gets tough
or since they are between the ports(left to right), maybe they could even do some form of symmetric port balancing
but its probably rubbish, I dont know
working on measurements
maybe later today
Old 29th November 2012, 09:46 PM   #29
side view of ports, and 'air-traps' with stuffing
Old 1st December 2012, 09:45 PM   #30
changed to 6 ports instead of 4
results in more available volume
also makes it easier to assemble
now measurements and cutting plan
shoot, forgot bracing on back panel
if you want to have the woofer countersunk, it could be done by adding another front baffle ?
Bass Reflex Enclosure for Beyma 10BR60 -_nando-_ Multi-Way 7 22nd June 2013 01:25 PM
Tqwt with Beyma BEYMA 12XA30/Nd simulation sladdbarn Multi-Way 11 18th May 2013 03:58 PM
15" Beyma SM-115N Giarsun Multi-Way 2 3rd October 2007 07:22 AM
Enclosure for Beyma 12CX - whats good? freddi Full Range 0 24th November 2006 04:12 PM
Beyma SM Series DarkOne Multi-Way 2 6th August 2006 06:57 PM
Copyright ©1999-2017 diyAudio
