Beyma SM-112/N Enclosure Help
Old 1st December 2012, 11:19 PM   #31
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
ok, quitting that silly bracing
double panels instead
(front, back, top, bottom)
Old 1st December 2012, 11:47 PM   #32
and much simpler
Old 2nd December 2012, 10:58 AM   #33
Vostro is offline Vostro  South Africa
Vostro's Avatar
yeah
Looking simpler to build now, thanks
Old 2nd December 2012, 11:38 AM   #34
good, glad we agree
yearly days still
this one is 155 liter
we can shave a bit more off
one more to come
I can make it a bit less deep, or slightly more narrow
which would you prefer ?
Old 2nd December 2012, 12:41 PM   #35
Vostro's Avatar
Maybe lightly less deep please, could be abit higher or wider.
Old 2nd December 2012, 12:59 PM   #36
less deep it will be
any special max depth number you would prefer ?
Old 2nd December 2012, 03:09 PM   #37
Originally Posted by Vostro View Post
.......could be abit higher or wider.
can be about 500mm deep, with present hight and width
but could be about 450mm deep, if you like
if so, would you prefer wider or higher
no problem at all, your choice
Old 2nd December 2012, 07:53 PM   #38
tricky, but here it is, more or less
still checking for errors
small adjustments to make it all fit when assembling
width measurements shows to be especially tricky due to the Onken style porting
but its close now
Old 2nd December 2012, 10:47 PM   #39
double panels gone, except for the front
instead new bracing
and you can always put on more layers afterwards
no more changes, and thats a promisse
measurements tomorrow
File Type: jpg sub hjælp beyma 134liter in the works 3.jpg (116.2 KB, 104 views)
Old 2nd December 2012, 11:13 PM   #40
more bracing
hey, we could call it 'The Muffler Sub'
File Type: jpg sub hjælp beyma 134liter in the works 3.jpg (118.3 KB, 100 views)
Beyma SM-112/N Enclosure HelpHide this!Advertise here!
Bass Reflex Enclosure for Beyma 10BR60 -_nando-_ Multi-Way 7 22nd June 2013 02:25 PM
Tqwt with Beyma BEYMA 12XA30/Nd simulation sladdbarn Multi-Way 11 18th May 2013 04:58 PM
15" Beyma SM-115N Giarsun Multi-Way 2 3rd October 2007 08:22 AM
Enclosure for Beyma 12CX - whats good? freddi Full Range 0 24th November 2006 05:12 PM
Beyma SM Series DarkOne Multi-Way 2 6th August 2006 07:57 PM
Copyright ©1999-2017 diyAudio
