Beyma SM-112/N Enclosure Help
Old 26th November 2012, 06:26 PM   #11
Vostro is offline Vostro  South Africa
Vostro's Avatar
Thanks 55x55x55cm is compact
Not tiny but Ill make place to fit it
MDF is cheap here, but if ply is better I can shop around.
Old 26th November 2012, 06:30 PM   #12
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
for a sub, I think MDF would be ok to use
how thick MDF ?
finish ?
tools?
Old 27th November 2012, 03:05 PM   #13
Vostro's Avatar
16mm MDF like picture,
Sadly I live in an appartment and dont have the greatest of tool selections,
I have Hand tools, like drill and jigsaw,
My wood supplier cuts wood, so I usually get most of the cuts done, then alter at home as needed,
If I need more help I can always contact a friend.
Old 27th November 2012, 03:12 PM   #14
16mm ? it will need some 'tricks'
I suppose you dont have clamping tools, and thus need to use screws ?
you are familiar how to use screws with MDF ?
what kind of screws ?
what kind of glue ?
btw, your wood supplier, he does cut it 100% accurately and smooth, right ?
Old 27th November 2012, 04:08 PM   #15
Vostro's Avatar
well to be honest, Im not sure, i would guess piloting holes and using wood screws with woodglue,
But advice is needed,
No there curts are sometimes not square enough, but I'll chat to them and ask them nicely to be exact. they use big table like saws and are as smooth as in the pic above, but thats just a offcut from previous project.
Warm Regards
Old 27th November 2012, 07:05 PM   #16
I will work on a design according to your skills, tools and materials
I may have something we can look at tomorrow
basic design idea
corners are ports
but may still change
Old 27th November 2012, 09:06 PM   #17
ports moved a bit
dont worry about the punched lines
they are for my own pleasure only
Old 28th November 2012, 08:13 AM   #18
assembling point of view, starting with inner structure
Old 28th November 2012, 09:57 AM   #19
and more detailed
Old 28th November 2012, 11:30 AM   #20
corrected for calculated port size
4 ports of each 200x48mm
but so far just an estimate
Beyma SM-112/N Enclosure HelpHide this!Advertise here!
Bass Reflex Enclosure for Beyma 10BR60 -_nando-_ Multi-Way 7 22nd June 2013 01:25 PM
Tqwt with Beyma BEYMA 12XA30/Nd simulation sladdbarn Multi-Way 11 18th May 2013 03:58 PM
15" Beyma SM-115N Giarsun Multi-Way 2 3rd October 2007 07:22 AM
Enclosure for Beyma 12CX - whats good? freddi Full Range 0 24th November 2006 04:12 PM
Beyma SM Series DarkOne Multi-Way 2 6th August 2006 06:57 PM
Copyright ©1999-2017 diyAudio
