#21 |
I just realized I'd never posted the Hornresponse plots
www.stuffscottbuilt.com |
#22 | |
www.diysubwoofers.org |
#23 | |
Scott
#24 |
What are the outside dimensions of the cabinet?
My audio and DIY blog: http://phimusic.blogspot.se/ |
#25 |
I just reread thru the post...Congratulations on the girls!!!!! They sure change things...
Aggressively Passive |
#26 |
SpeakerScott: what plate amp did u use?, good match?
gychang
-- Good sound from Phoenix, AZ
#27 |
27" Tall, 23.75" Deep, 14.875" wide.
Or 68.58 cm * 60.325 *37.7825
#28 | |
You're telling me! Yikes. My house has exploded in pink and perfume.
#29 |
I use a BASH500 from Parts Express. I didn't build it into the cabinet though...its in a separate enclosure. I find amplifier matching to be an awkward term. It's enough power, sounds great and has the features I need. So, yes? It's a good match?
Scott
#30 |
Scott,
Do you happen to have a list of the sizes of the pieces illustrated in your cutlist layout diagrams. The illustrations you provided are great, but unless I make a full size layout with pieces positioned as in your "relative position" illustration, there is no way for me to know (as an example) the size of the piece labeled as "9" Thanks in advance... Joe L.
| FS: TH-18 PA tapped horn subs! | m R g S r | Swap Meet | 7 | 5th March 2013 03:42 PM |
| Can a Tapped Horn have a negative taper within the horn path? | BP1Fanatic | Subwoofers | 6 | 13th February 2010 06:04 AM |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| Manifold mid bass horn entry??? | fredos | Subwoofers | 0 | 28th October 2008 09:32 PM |
