Old 24th November 2012, 02:26 AM   #11
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Originally Posted by Brian Steele View Post
Nice work there. Now for some impedance and FR measurements, to see how close you got to the target response
That is next, but it'll have to wait for after the holiday weekend. Too many relatives to visit with....
www.stuffscottbuilt.com
Old 24th November 2012, 05:36 AM   #12
maxo is offline maxo  United States
picsssss piicssssss please
Old 24th November 2012, 06:03 AM   #13
ßart West-VL.'s Avatar
+1
Old 24th November 2012, 07:16 AM   #14
NEO Dan is online now NEO Dan  United States
NEO Dan's Avatar
Default Great Scott!
And so it begins...
It's all down from here man
Nice work.
Almost forgot, that little patent blurb is not correct FYI.
Dan
Old 25th November 2012, 06:48 AM   #15
stewin is offline stewin  Kenya
hi scott wow cool work
please post the response and sensitivity specs
Old 27th November 2012, 01:19 AM   #16
ok, holidays over....
Old 27th November 2012, 01:43 AM   #17
Default As fast as I can....
Sorry guys, still trying to recover from the holidays! My wife and I adopted two little girls this year. Yikes. Very...different life! I used to go to high end restaurants and try different molecular gastronomy recipes. Now it's Hello Kitty and casseroles.
I'll try and get at least an impedance sweep done before the end of this weekend. In room response is a possibility too...anything more than that might have to take a bit.
I will say this..I'm as interested as anyone. My current sub is a dual Peerless XLS 12", 12" XLS PR in about 80L. I might prefer the sound of the Dayton. It is waaaaay closer subjectively than I ever thought it would be. When I was running all of the simulations in Hornresponse, I thought....nah...these numbers are all too good to be true. Now...I'm believing. I've got a Dayton 12" Titanic MK III design that I might build next. 6dB more output, by calc...than my dual Peerless XLS 12 sub.
My wife is so going to kill me.
Scott
Old 27th November 2012, 02:00 AM   #18
ayee
Old 2nd December 2012, 11:57 PM   #19
Okay I was able to do a quick impedance sweep. Which took two hours, because Praxis was being weird. My thoughts:
1. It's even closer than I expected...even up to the higher order modes.
2. Looks like some bracing around the mouth might be in order...even for this sub.
3. Looks like the copper pole cap is doing it's job on inductance, though the higher than predicted impedance in the 300Hz to 2kHz is a bit weird.
Scott
Old 3rd December 2012, 12:00 AM   #20
NEO Dan's Avatar
Looks good Scott,
REW AKA Room EQ wizard could be used to make the measurements...
Dan
FS: TH-18 PA tapped horn subs! m R g S r Swap Meet 7 5th March 2013 03:42 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Manifold mid bass horn entry??? fredos Subwoofers 0 28th October 2008 09:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
