How to Cram the Wrong Driver into a Tapped Horn
Old 24th November 2012, 11:55 PM   #11
L.rivera92172 is offline L.rivera92172  United States
patrick im a noobie here but couldnt you use polyfill to change the qts or a linkwitz transform Sub-Woofer Controller and Linkwitz Transform Subwoofer Equaliser to change the qts of your subs
Old 25th November 2012, 10:34 AM   #12
Don Hills is offline Don Hills  New Zealand
For designing speakers that require filtering, non-classic alignments and accounting for cabin gain, I recommend Brian Steele's PORTED.XLS spreadsheet. (diysubwoofers.org/design/ported.zip)
Old 17th March 2013, 06:01 PM   #13
kees52 is offline kees52  Netherlands
Hi Patric
I have a infinity woofer who I did want to use for a tapped horn, because I did read your stuff in my learning proces of folding and designing a tapped horn I begin to think of a tapped horn in home envirionment is a need, I have A PPSL box designed but only in sketchup, and busy with that tapped horn with the infinity 1260W
Something is wrong, when I try to make a vented box as a opening to tapped horn like you advised here I get not a very good respons from this woofer and in a closed box it get high fs.
I put here some stuff can you let go your experience around so I learn more, I am a amp designer that is for me not so difficult but box yes I have to learn some things.
Further I think the TS are some strange, but when I do a chech with martins TS check sheet it looks everthing is fine, maybe you can check also, see al in the pictures.
I do ask also to prevent use a wrong speaker, it has such low qts for such high mass??, I do when I am ready with the box use limp to measure manufactorys are not always trusted, infinity is a good label though see pdf for TS parameters...
kees
Old 18th March 2013, 09:32 PM   #14
xaero is offline xaero  Latvia
Hi. This is my tapped horn for car, outer dimensions are 455x420x775 mm
Drivers are 12'' lanzar opti 1232d @ 1ohm load each
2 drivers parallel 1v input 2,0 x pi. I will use two hifonics brz 1200.1 amplifiers in 1 ohm load each, did not measure real spl, but i really like how it sound.
Old 19th March 2013, 05:28 PM   #15
m R g S r is offline m R g S r  United States
Isn't that more of a TL than a tapped horn?
Old 19th March 2013, 07:05 PM   #16
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Looks like a tapped quarter wave pipe or tube (TQWP or TQWT)...no flare tapped horn.
Old 8th February 2017, 05:36 PM   #17
Doc777 is offline Doc777  United States
Hey Pat. Did you ever get to test out your TC2's? Working on a similar build here. Leaning towards 4 alpine SWS 10D4 or JBL GT5-10.
I love this room!!!
Old 8th February 2017, 10:27 PM   #18
tb46 is offline tb46  United States
Hi Doc777,
You do realize how old this thread is? Anyway, here is a thread by Patrick Bateman where he uses (among other things) 4ea. Alpine SWS-10D2 in a TH: $300 TH-50 Knockoff
It'll take a little effort to work through that particular thread, but may well be worth it.
Oliver
Old 9th February 2017, 09:03 PM   #19
Not knowing how you made out with your project left me curious. Thanks for the new thread. Will check it
I love this room!!!
How to Cram the Wrong Driver into a Tapped HornHide this!Advertise here!
what driver for tapped horn? vadi Subwoofers 11 12th April 2010 08:22 PM
Tapped Horn and Driver resonance Freq. Bent Subwoofers 44 17th April 2009 12:05 PM
Double Driver Tapped Horn MaVo Subwoofers 28 23rd January 2009 06:38 PM
Copyright ©1999-2017 diyAudio
