I bought some wool The Madisound Speaker Store for stuffing an OD_ML_TL.
It seems to be a random mess. I have heard that it should be oriented in the direction of the tuned length. Do I try to comb it straight, like long hair? Should I wash it before using it? Is there any moth proofing that I could use? Or, do I just install a light screen in the port to keep moths out? Any other recommendations? Help out a noob, Thanks, Dave
<---My Transmission Lines from a prior life Top one Tweeter...Bottom one definitely a Sub |
#2 |
I don't know what your wool looks like, but the wool I've used (sourced from a sheep farm) has:
1) been a jumble of fibres (and colours). That's the way it will look unless its been 'processed' in some fashion by craftsperson/mill. 2) been washed. Trust me, if it hadn't you wouldn't even wonder if it was clean. 3) never had a problem with moths. I don't know if the moth stories are fiction or real, but I've never had an issue. Though, perhaps, location is a factor. I live in the country, in a semi-arid region, and though we do have moths in summer, perhaps they're the wrong 'type' to munch on wool. Hope that helps. |
#3 |
You are not going to card the wool. It is clean and ready to use.
I do not believe orientation has anything positive to do with it's performance, but density through the line is. I would put a screen over it to keep the mice out. I only use wool in sealed boxes (and have shifted back to FG anyway) as I don't want to pump wool fibers into the room due to allergies. If I tried another TL, I would use their acousta-stuff. |
#4 | |
FYI: b ![]() PS: Bedtime in seconds..(I've been in Sickbay for almost 3 weeks..)
| Wish you could nail down your copper wool holder? | BillEpstein | Tubes / Valves | 6 | 5th July 2011 05:57 AM |
| Rock Wool Equivalent Volume | jlsem | Multi-Way | 4 | 17th August 2010 03:30 AM |
| using 'steel wool' as box stuffing | terry j | Multi-Way | 3 | 24th October 2008 05:19 PM |
| long haired wool | vitalstates | Full Range | 23 | 7th February 2007 04:09 PM |
| Glass wool. Is it dangerous? | sachi | Multi-Way | 15 | 20th March 2005 01:31 AM |
