A bench style cabinet subwoofer 2x15 closed
Old 18th January 2013, 03:35 PM   #61
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
tb46,
separating the subs would also loosing a nice 220cm wide bench! You can see some of the bench in the photo at post #39 and in a 3D picture at post #32
I really hope that drivers would come soon.. The weather has been too cold for skiing and snowmobile riding (today -29C in the morning) Blaah, some more sketching, modelling, simulating, ..and perhaps som more wine?
AINOgradient speaker project
Old 18th January 2013, 04:33 PM   #62
ßart West-VL. is offline ßart West-VL.  Belgium
ßart West-VL.'s Avatar
Jahuzi, here in west Belgium we had two mornings of -14°C, pretty rare.
But seeing -29°C is unimaginable
I think tb46 meant to say: change one baffle from the PPSL to the far end of the enclosure.
Break in your loudspeakers at 35% RMS power Right-click'save as...'
Brown noise mono 192kbps(hit "repeat")
Old 18th January 2013, 05:04 PM   #63
tb46 is offline tb46  United States
Hi Jahuzi,
Keep the bench, just move one driver to the left hand end of the bench.
Oliver
Old 18th January 2013, 08:15 PM   #64
Juhazi's Avatar
Ok, I mentioned turning boxes in message #49. It is easy but first I want to hear the ppsl. Check also version 2 in message #1
According to hunecke simulator, moving speakers sideways along the short wall doesn't change 40Hz hump at all. Listening while laying on the floor helps! Fortunately I have 2 extra small subs.
Too many iterations so far I guess
Old 28th January 2013, 07:59 PM   #65
Juhazi's Avatar
So far still waiting for drivers...
I learned how to bake a baffle in Hornresp. Here is what to expect in 1pi conditions at maximum excursion
spl
phase
wavefront simulation
Old 30th January 2013, 02:36 AM   #66
norman bates is offline norman bates  United States
norman bates's Avatar
do you have a 1pi ?
That is a corner right ?
Ideally that is a concrete corner. otherwise, I wouldn't trust the simulation, let alone all the variation of bass in a room............
Why is there the phase wrap around 48hz ???????
Old 30th January 2013, 08:55 PM   #67
Juhazi's Avatar
I'm not sure of the phase shift but I guess it is the plemun - depth, width, height? I mus try to change parameters and see what happens.
Pi environment definitions Radiation Space in a Room
Old 31st January 2013, 09:10 AM   #68
dctech is offline dctech  Canada
Love the dual function bench/sub.
Sorry to butt in....
Don't use MDF, go with 3/4 baltic birch or 3/4 marine grade plywood (11-13 ply).
If you want smooth, fast response be aware of your amps damping factor as that dictates how well it can stop and start the moving mass of the driver.
A properly constructed, sealed enclosure, will always yield best balance of spl and sq.
Especially for home theater.
With a ported enclosure, when you send signal to the driver below the tuned frequency, the driver no longer sees the box and it will over-excurd.
If your subs are 15's, what is the next largest woofer in your system?
Old 31st January 2013, 09:29 AM   #69
Juhazi's Avatar
dctech,
The cabs were made of 21mm spruce plywood and they are closed, the drivers are optimal for closed cabs. The slot cavity has some resonance properties.
Hypex DS2.0 has damping factor 500 - enough?
My other subs are 10" and 8" BR, F6 around 35Hz, commercial subs with plate-amps.
So far I'm still waiting for the drivers....
Old 31st January 2013, 08:10 PM   #70
zobsky is offline zobsky  India
zobsky's Avatar
Originally Posted by Juhazi View Post
adason, I'm just trying to tell that I want good transient and "controlled" subbass. English is not my native language and I'm trying to avoid tautology.
You're ignoring the possibility of room modes.
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
A bench style cabinet subwoofer 2x15 closedHide this!Advertise here!
I like the Fonken Style cabinet, but... wcwc Planet 10 hifi 20 9th February 2012 05:53 PM
2x15 cabinet volume Austin Duggan Multi-Way 8 3rd April 2008 07:07 AM
optimal speaker for closed cabinet? Jan Volkering Subwoofers 1 2nd December 2007 08:22 PM
Magnavox 2x15 Guitar cabinet? ThSpeakerDude88 Multi-Way 0 12th October 2006 07:12 AM
New Speakers for 2x15" bass guitar cabinet. Nate Groadie Multi-Way 0 20th May 2003 04:38 AM
Copyright ©1999-2017 diyAudio
