A bench style cabinet subwoofer 2x15 closed - Page 4 - diyAudio
Old 23rd November 2012, 01:55 PM   #31
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Hello Houston, the Project has been launched!
Just visited a carpenter and hardware store. The sides will be made of 21mm spruce plywood and the cover is a wenge-laminated LDF board, 40mm thick. Plywood will be cut to precise sheets for assembly, I will cut internal braces myself. I'll get the parts some time next week. The front panel might be a sandwich structure, insulation wool and a mdf board. Finally dark blue wallpaper glued onto it, like all walls of this home theater room.
The bench will be born quite soon but the ppsl sub some time next year.
Thank you all, specially "Norman" and Oliver
Juha
AINOgradient speaker project
Old 24th November 2012, 10:40 AM   #32
Juhazi's Avatar
Default PPSL 518 picture
New and better sketches of my ppsl 518L sub and my theater room. The curtain rod is actually a 100" screen.
Old 27th November 2012, 07:26 PM   #33
Juhazi's Avatar
Knock on Wood
Some knuckle knock test i made. Later on I'll post also measurements of finished cabinet walls.
Method:
sheet of board held hanging in air with fingers
Microphone 10cm from the board on the opposite side of knock (knuckle)
Apparatus Zoom Q3, hardware 2.01, Gain L, 24/96000Hz wav-format
Analysis Audacity 2.0.0 Windows 7 64-bit (program 32-bit)
Sorry, the graphs are no in same scale -look at the form of graphs.
Spruce plywood 21mm 42x104cm (the 50hz humming is room mode making the board resonate! I tested aurally in different rooms)
Spruce plywood 31mm 60x40cm (microphone gain H, clipping at knock)
MDF 25mm 40x85cm
Old 28th November 2012, 04:59 PM   #34
Juhazi's Avatar
Boxes starting to build up. Just five outer walls put together. The weather is freezing now finally so I must work inside.
Old 28th November 2012, 08:04 PM   #35
norman bates's Avatar
back in my day, we trusted our ears.
Old 29th November 2012, 12:06 AM   #36
That would have been the 20th century. Now trust is passe. We must trust the meters. Sorry, I meant monitors. Sims not sound. Alriteythen...
Old 29th November 2012, 05:22 AM   #37
Juhazi's Avatar
Guys, I did the knock measurements inspired by the Harbeth speaker discussion.
I had already decided the cabinet material for my subs. The general design was inspired by the space and location available. Also closed box was a prejudice. Then I had to find drivers for cabs and I did Unibox and WinISD simulation to see what was well expected. The slot idea came after that. And because I can't use Hornresp, and seems like ppsl is not well documented, it's interesting to see how it measures.
Old 29th November 2012, 07:57 AM   #38
lol, all is good.
I'm sure it will sound great.
Old 20th December 2012, 05:53 PM   #39
Juhazi's Avatar
Some progress before the holidays. Cabinets are ready but the drivers are missing. A Hypex DS2.0 will deliver the power with eq and adjustable phase.
You can see my lovely carpenter givng the strategic inner structures the finishing touch.
The cabinets with wallpaper coating and the cover. You can also see some of my multiple bass traps and the minute JBL 10" sub.
Happy Christmas!
Old 21st December 2012, 01:21 AM   #40
The drivers are going to be sharing the box air, right ?
were you using a pipe to couple them together ?
what driver were you using again ?
Qts, vas, Fs ??????
And how big a sealed box do you have ?
Norman
I like the Fonken Style cabinet, but... wcwc Planet 10 hifi 20 9th February 2012 04:53 PM
2x15 cabinet volume Austin Duggan Multi-Way 8 3rd April 2008 06:07 AM
optimal speaker for closed cabinet? Jan Volkering Subwoofers 1 2nd December 2007 07:22 PM
Magnavox 2x15 Guitar cabinet? ThSpeakerDude88 Multi-Way 0 12th October 2006 06:12 AM
New Speakers for 2x15" bass guitar cabinet. Nate Groadie Multi-Way 0 20th May 2003 03:38 AM
Copyright ©1999-2017 diyAudio
