Reason the port works is there's little (no) pressure in one end and chamber in the other, by stickin a horn behind the port, you change this so the port sees pressure in both ends, so as a result you "just" get a front loaded chambered horn, Now that can work very very well, but you don't get any benefit from the ported design....
There's no such thing as a free lunsh...
OK maybe you mean a horn shaped port like the red, green, black and blue units here? Those are dual 10" woofers with horn ports in the centre. There is also a horn flare on the back that acts to 'gather' the sound into the port.
Actually I was the proud owner of a pair of Altec A2's in the 80's. A funny thing happened, a couple of guys from Nasa / Stennis came into my studio started taking tape measurements and bought them for a price I cant bear to think about. Grrrrr. Stupid kid. (me)
Yes the ones near the outsides of the picture.Cal? Red, green,black and blue units??
Yup, all the cabs that look like that meet the description. Those horns are actually ports, double ended if you will. The difference in the colour is because I had a bunch of old spray paint cans laying around. Guess how much was left in each?I see something that looks like a hf horn in blue??
Maybe turn up the brightness on your screen my friend.
Yes and to think they used to keep us awake at night when we were kids. Now we welcome them into our homes.Large grey monsters...
Oh wait...they don't fit through the door. Good thing, they can scare away all the bogie men outside.
Cheers.
Cal,Yes the ones near the outsides of the picture.
Back in the day a port of that size was called a venturi port, not a horn loaded port.
All a matter of size and semantics though .
Art
Art,
I can appreciate that and I'm glad you posted. If I used that term nowadays I might confuse the masses.
Who remembers a squawker, a drone cone, what a subwoofer used to mean or what a waveguide was? The evolution of the audio language I suppose. It's not talked about or utilized too much so I thought I'd 'describe' it instead.
Man, I miss the old days.
Cheers Art.
Cheers Art.
Hi, read up about Danleysoundlabs Synergy horns. To my understanding many of these are front loaded horn, with a fairly short horn, loading down to maybe 100Hz, with a port tuned for maybe half that, to fill in the bass below where the hornloading drops off.
Hornresp should simulate this general concept fine.
The Synergy style horn can be simulated as an offset conical horn with bass reflex.I'm.a geeky kind of guy, I don't know why I'm letting Hornresp intimidate me. Thanks.
If the ports are located towards the mouth, the simulation should be fairly close to reality in the horn passband.
are we talking about a klipsch lascala ?
Something like that ?
There are ported W-bins (I had one), but the port doesn't firing into the horn (least ones I've seen).
The tuning frequency is probably way lower than what the horn mouth/length is loading at, so I doubt if it was ported into the horn, that it would have helped any.
here is a thread on porting W-bins.
http://www.diyaudio.com/forums/multi-way/25493-folded-horn-w-bin-porting.html
This post actually really excites me! A while ago I posted something about "a vented horn"
Heres a link to my post
My guess is that it would shift the port freq way out of what it should be in free air. Think about it. The whole idea of a horn is that it serves as an acoustic transformer, to convert high pressure at a low volume of air motion to low pressure at a high volume of air motion. It's not a bad idea. I just don't think you can start with a system that was tuned for free air and stick a horn on it. If you had a way to measure things, you might be able to make adjustments to the port and box size to get it right.
- Subwoofers
- Either brilliant idea, or exceedingly ignorant.
