Infrasonic Speaker - Need advice for undergrad thesis project
Old 19th November 2012, 03:09 PM   #51
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Originally Posted by weltersys View Post
Good work James!
Does only 100 watts make the drivers hit Xmax (13mm)?
One note, though a 2 food depth is great for wood use, the Lab 12s are 12.25" and would either need to be put at a bit of an angle, or a divot chiseled (or routed) out at the top and bottom of the speaker mounting location.
For a cabinet that big, I'd want to put at least four or even eight 12", 129, 136 dB at 15 Hz in room...
Don't try it full tilt boogie in a plaster and lath constructed house unless you plan to rebuild .
Art
Hey Art,
yep, 100W already hits xmax, it's amazing how much drivers will flop around at low frequencies like that. I'd much rather put something like the TC Sounds Pro 5100 in a horn that size, but seeing as that alone is over OP's budget..... better hope he has access to cheap lumber
I know about the width issue, my proposed solution is to stagger the drivers somewhat, like the circles in the % sign.
Additionally I would route a few circular spacers from some spare wood so that the further forward driver can be mounted upside down. This will equalize the path length through the horn a bit, and also reduce distortion with the woofers operating push-pull. And at this sort of low frequency, any distortion reduction will be much needed - even with that, I wonder how much THD will be in a system like this - low enough for it to even be worthwhile?
Regards, James
Old 19th November 2012, 03:28 PM   #52
Deafuser is offline Deafuser
Default Where's the music, Fella ?
I take it you can't compose and record this "Infra-music", until you have the loudspeaker built? So I'm curious, musical instrument speakers are usually called "Producers", and Hi-Fi "Re-Producers"! Shouldn't you be looking at a PA forum?
Also, will you allow us to have a recording of your "Infra-music", please? I'd love to hear my sub playing a tune other than a bass-line or rumbles and explosions!!
Good luck
Old 19th November 2012, 04:00 PM   #53
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by jwmbro View Post
Hey Art,
I measured the distortion of dual Lab 12s in my Keystone TH with about 400 watts per cone, it was still pretty clean. At 100 watts, I'd think your design would not have much distortion at all, and the even order distortion components would be perceived as part of the music.
PP reduces even order distortion, leaving odd order (not so musical) distortion.
With Lab 12s, the vent noise at high excursion in a TH is quite easily heard, I would think it would be more objectionable than the second harmonic distortion it would reduce. For this experiment, having the magnets towards the throat would probably be better.
The TC Epic 12" has a lot more excursion than the Lab12, for not much more money, with a monster excursion limited cabinet like you have designed, definitely worth it.
Art
Old 19th November 2012, 04:06 PM   #54
weltersys's Avatar
The music could be composed on headphones, which have response as low as the OP plans to go.
Headphones don't provide the tactile sensation of a sub operating at the same level, so some adjustments will need to be made for the sub(s) that ultimately is built or rented.
Changing the sub from the composition room to a playback venue will require further adjustment.
Old 19th November 2012, 04:08 PM   #55
jwmbro's Avatar
Art
Thanks, I knew there was a TC Sounds subwoofer with a lot more excursion than the Lab, but for some reason I only saw the LMS-R 12, which is a lot more expensive.
The Epic 12" would probably be a worthwhile upgrade for this cab.
Regards, James
Old 19th November 2012, 06:40 PM   #56
adason is offline adason  United States
adason's Avatar
these guys did 160dB at 16Hz...
http://www.youtube.com/watch?v=FdNultZ4QT8
Old 19th November 2012, 06:42 PM   #57
m R g S r is offline m R g S r  United States
Who? ^
Old 19th November 2012, 06:49 PM   #58
weltersys's Avatar
MythBusters subwoofer - YouTube
The Mythbusters 161 dB car engine powered cone was funny, but not musical.
The OP needs musical sound in a space (presumably) larger than a two seat car.
Old 19th November 2012, 07:11 PM   #59
bentoronto is offline bentoronto  Canada
Yes, Rice-Kellogg drivers are little motors and go to DC. But at a fraction of a wave-length, the radiation resistance is miniscule. Why are some people thinking that is the right way to shake the air?
Lot of confusion about dB scales. For some purposes, you want to talk about what people mean by "equal loudness for me," very for use very roughly as speech intelligibility, or maybe to assess some kinds of industrial noise damage, and that is when to use dBA (at least as far as the curve has been plotted with human testing).
But if you are talking about force or ear-drum impingement or some psycho-physical measures, dBA has no special significance.
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and now posting a folded 17-foot pipe sub tested with railroad recordings and the Queen's Birthday Salute 1957)
Old 19th November 2012, 07:25 PM   #60
cyclecamper is offline cyclecamper  United States
I'm not sure exactly what you want to do, or what kind of study you want. While your power requirements are high, you don't need as much speed so in many infrasonic designs weight is not as much of an issue.
Be careful of some tactile transducers which are actually out-of-balance rotary motors which vibrate but NOT AT THE ACTUAL FREQUENCY APPLIED. They change speed with the volume of bass, but are definitely not musical.
Tapped horns are a possibility, but the speaker driver can be a problem; you may need to dope down or even fiberglass the cone to add mass and strength. You can assure linear motion by using something like two sets of bifold doors at right angles to each other. Hinged sheets of plywood...
There are some better options. Some use mechanical or fluidic ampilfication, which allows you to use thousands of horsepower from chemical combustion engines or huge electrical motors driven by your local nuclear or coal electircal plant, without requiring enormous audio amplifiers. Others are just very efficient, requiring that you rent a few hundred-thousand watts of power amplifiers.
The most powerful and economical devices are not reproducers of complicated changing audio waveforms, but produce or generate sounds themselves, more like instruments than speakers. The most powerful use other main sources of power, not an amplifier (though an amplifier may provide control). These include the very large recirculating wind tunnel with diversion vane designs that Danley built. The audio output can be huge, if the wind tunnel blowers are powered by large enough motors or engines. The diversion vane can be driven and controlled several ways, including mechanical crank or cam as an "infrasonic siren" generator, or via an electric motor or electric linear motor as an infrasonic speaker. You can consider using the linear actuator motors that drive the seek arms in old huge disk drives, for instance the DEC PDP-11 drives. Big deep magnets drive a long hinged arm, all very lightweight to move quickly. If you can find a source of several, they can also drive cones and horn-loaded cones or tapped-horn-loaded cones. Usually such systems require some sort of feedback mechanism so the lienar motor also appllies braking forces.
Very very long organ pipes can be built from large fiberglass and plastic sewer pipe at reasonable cost and make really substantial low-frequency output if driven by a large high-power blower. Here harnessing resonance is the key, both in the pipe and in the room. Consider renting a diesel air compressor trailer, one of the really big ones on a semi-trailer for sandblasting large buildings and bridges. Of course, each generally makes only one note.
Another viable alternative would be the discontinued Danley "Intersonics" brand of rotary-drive subwoofer, or one of the many homemade clones and variations. These were driven by 4-pole commutated DC rotary motors which responded well to conventional amplifiers. The rotary shaft drives belts to cones that are horn-loaded; the belt is pre-loaded in tension via something like a fiberglass spring. Often two belts are used, wound on the motor shaft and exiting in opposite directions so that forces on the motor's rotary shaft bearings are balanced. They are extremely extremely efficient and LOUD despite the fact that all the power comes from the amplifier. There's no wasteful voice coil overhang resistance outside the magnetic gap; Danley used to compare it to a "commutated" voice-coil in trying to explain its efficiency. Close tolerances due to rotary barings helps too. You generally start with surplus capstan motors from large mainframe disk drives.
Other efficient drivers for very low frequncies use "moving-metal". The voice coil includes a moving iron magnetic structore, so that the magnetic field that is generated by the portion of the voice coil that is outside the magnetic gap is still coupled to the stationary magnetic structure. Most Hartley sub drivers fall into this "moving iron" category, and also have rather large cones (and prices).
The Thigpen is a very interesting design, but to really have sufficient output it needs to be significantly scaled up until it's rather dangerous, and to be in a baffle and low-pass tunnel to minimize blade noise. To understand it, you can study variable-pitch aircraft propellers, but you will need to vary from no pitch at all to significant pitch. It is another true mechanical amplifier, using a small control motor signal (which varies the blade pitch) to control the work output from the huge power of the main engine and flywheel. The fan spins at a relatively constant and somewhat irrelevant speed, but the blade pitch is modulated at audio frequency. There are many design vairations, from mechanical linkage arms off of a slip-ring (kind of like a clutch throwout bearing) which is reminiscent of variable-pitch aircraft props, to systems that put the modulation motors on the rotating mechanism and get power to those small servo motors via brushes or non-contact coils etc. If you could move the "pitch" lever on a turbo-prop plane at audio frequencies, you'd have a thousand-horsepower subwoofer.
Then there's all kinds of more direct infrasonic sources which allow for some limited degree of control suitable for only certain kinds of study. For instance, it is difficult to predict when lightning will strike and provide a suitable low-frequency spike. But a stick of dynamite in a crater lake can be triggered electrically with great accuracy.
He's a busy guy, but you need to talk to Tom Danley and/or study his designs on the old "bass list".
Infrasonic Speaker - Need advice for undergrad thesis projectHide this!Advertise here!
Thesis idea: Speaker distortion detection LG Multi-Way 13 10th November 2008 03:19 AM
looking for advice on a first speaker project farkus888 Multi-Way 10 25th April 2007 10:05 AM
My first speaker project. Any advice? Jim85IROC Multi-Way 10 14th December 2003 04:11 AM
Need Advice for Speaker Project Tophet1 Multi-Way 2 11th August 2003 08:39 PM
