JBL 2241H subwoofer - makes buzzing noise
Old 15th November 2012, 06:39 PM   #11
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Thanks for the great advice.
I was thinking of carefully cutting the dust cap out and then gluing it back on, if I found the problem and fixed it.
I tried pressing on where the foam and surround meet and that did not stop the vibration.
I also tried pressing other parts that were moving but that just caused buzzing against my fingers
Old 16th November 2012, 12:44 AM   #12
Jimmy154's Avatar
Ok, I'm going to cut off the dustcap!
Some body stop me!
Old 16th November 2012, 09:52 AM   #13
djk is offline djk
djk's Avatar
Tap sharply on the dustcap/cone assembley.
If you hear a 'sproing' type sound the coil has loose turns and the driver needs to be reconed.
Sometimes when you remove the cone the coil looks like a burnt Slinky toy.
Candidates for the Darwin Award should not read this author.
Old 18th November 2012, 05:12 PM   #14
badman is offline badman  United States
badman's Avatar
Update? Curious to see what you did to that poor woofer
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 21st November 2012, 12:27 AM   #15
Jimmy154's Avatar
Decided not to use it and put it on ebay.
Needs too big of a box.
Also I discovered the 2242H has much lower distortion, according to JBL pdfs for the two drivers.
I'll get a messed up 2242H that needs fixing at some point though
Old 21st November 2012, 01:52 AM   #16
DUG is offline DUG  Canada
If there is an "auto shutdown" feature on that sub there could be bad relay contacts.
I had one like that.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 21st November 2012, 01:55 AM   #17
Jimmy154's Avatar
I think you had something different.
This is just a driver.
Old 22nd November 2012, 03:14 AM   #18
Amplifier problem maybe?
Old 22nd November 2012, 04:27 AM   #19
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
I have had several JBL drivers where the spider comes loose from the voice coil in a small spot and that causes a buzzing, clicking sort of sound. the glue used on the Spider/VC seems to dry up and crack and the spider will break free in a small area and as the cone moves outward, the spider clicks as it moves on the VC former. doesn't do it on the inward moment as the spider is compressed by the cone.
It's not about what you can BUY...It's about what you can BUILD!
Old 23rd November 2012, 04:50 PM   #20
Jimmy154's Avatar
Thanks buddy
It wasn't the spider, but after I check the spider closely, I started to check the surround, more carefully. Looks like where the surround meets the cone there are a series of cracks that go around the cone and make noise.
What kind of glue can I use to fill the crack? Or what kind of glue is used to glue between the cone and the surround?
JBL 2241H subwoofer - makes buzzing noiseHide this!Advertise here!
B&C 18ps100 vs PD.186 vs JBL 2241H for hifi? pk Subwoofers 21 17th November 2012 02:45 PM
(4) - JBL 2241H 18" woofer subwoofer - NH, USA - $200/OBO a piece Jimmy154 Swap Meet 0 26th October 2012 04:40 PM
what makes power transformers buzzing samoloko Power Supplies 4 3rd December 2008 07:22 PM
Buzzing noise Puffin Subwoofers 2 1st August 2006 07:35 AM
My amplifier makes a buzzing noise Jimmy154 Solid State 7 25th October 2002 04:27 AM
