Peerless 830668 10"s bi-amped music only system
Old 23rd November 2012, 01:13 AM   #21
mikemarion is offline mikemarion  United States
mikemarion's Avatar
Originally Posted by Barleywater View Post
Going Linkwitz route is much better. DEQ allows sufficient control to smooth out and extend bass as desired. Box you are using is too big and too light to avoid panel resonances.
Do you have measurements of results?
Andrew
I have not purchased the calbrated mic yet. I saw that Parts Express gas one on sale now.
I might get that one.
Old 23rd November 2012, 03:59 PM   #22
mikemarion's Avatar
Originally Posted by Michael Chua View Post
I haven't tried the 830668 but my guess is that being a subwoofer, it is probably more optimized for the lower frequencies like in the 30-40Hz region. Great for movies but I find such drivers unsuitable for music. There's no punch and definition in the midbass.
For music, my preference is to use a woofer instead of a subwoofer. With the right woofer, it's possible to achieve a good balance between the low bass (40-50Hz) and the midbass (90-200Hz).
One such woofer is the 8" Usher 8137A. I have it in a 25L 3-way ported box. Very dynamic, punchy bass. If you prefer 10", check out SB Acoustics. I haven't tried them but judging from the specs, they have some models that look promising.
Mike
I'm going to stick with this driver. The problem was definitely over stuffing.
Old 25th November 2012, 01:08 AM   #23
mikemarion's Avatar
Andrew
I added back some light stuffing and took SPL readings.
Here are some measurements.
Testing procedure used:
-Created sine wav mp3 files at -6db down.
-Bypassed dbx 120A and DEQ2496.
-Played music at usual level (about 72db dbA slow response)
-Then logged these SPL readings in room at ear level with REED ST-805 SPL meter.
Old 25th November 2012, 05:48 AM   #24
Barleywater is offline Barleywater  United States
I was thinking more along the lines of impulse response measurements using swept sine technique, that could reveal more detailed view of system.
Andrew
Peerless 830668 10"s bi-amped music only systemHide this!Advertise here!
My Dipole bi amped system FaultlineCustoms Full Range 1 4th January 2012 09:26 PM
Full-range speakers in a bi-amped system? majerjack Full Range 29 25th November 2011 12:46 PM
choosing amplifier for bi-amped system soundnovice Multi-Way 10 16th November 2011 01:25 PM
2way bi-amped system with digital crossover stan Multi-Way 0 9th August 2010 03:08 AM
Peerless 850146 "replacement" 830668 fat_terry Multi-Way 13 24th January 2007 03:03 AM
