Triple driver - sealed. Pros/cons, and is it too much for a newbie - Page 10 - diyAudio
Old 15th November 2012, 11:33 PM   #91
MedPed is offline MedPed  United States
Tried playing with WinISD for the first time.
Cool stuff. I hope I am entering information correctly for new drivers.
Just to make sure I am doing things correctly, can someone just confirm two calculations.
1. For the Dayton RSS460HO-4 18"
Sealed cab volume 130.3 litres to achieve Qtc of 0.71.
2. For the Fi q18D2
Sealed cab volume of 109.9 liters to achieve Qtc of 0.71.
Does these numbers sound right?
You are guys are right about the ported though, can get very flat response down to 20 hz without any need for eq based on the sims, but I am worried about phase etc, and this being my first attempt, maybe sealed would be easier.
BTW, how does filling/insulation affect the cabinet. Does the WinISD sim assume a bare braced cabinet, or stuffed - and if so, with what?
The Fi is more expensive. Can get two Daytons within my budget - now expanded budget.
Old 15th November 2012, 11:42 PM   #92
weltersys's Avatar
Originally Posted by Moonfly View Post
I have to admit that I can also hear low 15hz tones from my headphones, but I do question why when with a sub I cant untill the level is pretty high.
The LRC is perfectly in phase at the crossover point providing all required parameters are met.
As a guess, I'd guess at the yellow.
There were three "guesses", the yellow is the tapped horn, which has a flatter phase response in the pass band than either the sealed or ported sub.
As you can see, the equalized TH is perfectly in phase with the delayed sealed top cabinets at the crossover point, you can still guess at the crossover frequency if you would like.
Furthermore, the ported cabinet can be matched to a sealed or ported top cabinet, as can the sealed cabinet.
Not sure what you mean by "LRC", but there are certainly many ways to achieve an integrated phase response at the crossover point, I'll take your word that "LRC" is one of them.
IIRC, the TH used a LR24 filter, while the sealed top cabinets use a BW24 to achieve the smooth phase response.
Headphones that can produce decent levels at 15 Hz must be closed, and therefore attenuate outside noise by some degree, making it easier to hear the LF tone.
Perhaps you should measure the SPL at 15 Hz required for you to hear your sub, likely it is around 90 dB SPL in a quiet environment.
However, 90 dB at 15 Hz only sounds about as loud as 25-30 dB at 1000 Hz, and unless you live in a dead quiet house, the ambient noise level may be above that, requiring a louder level.
Art
Old 16th November 2012, 09:00 AM   #93
Moonfly is offline Moonfly  Spain
2. For the Fi q18D2
You ideally want a sealed system to have a .5-.7 system Q. As such I always aim for somewhere in between, about .6 to .65. Q will raise slightly once room gain augments the subs natural response as well so thats another reason I like to aim a bit lower. Again, when you run dual sub, Q will again alter a touch. Dont forget that eq will also affect things like that. Personally, I think the Fi would work best in 150 litres as a minimum, otherwise it may sound a little boomy and probably sacrifice a little low end as well.
I dont have a driver file for the Dayton, if I get time I'll plug in the numbers later and have a look.
Stuffing helps make the sub sound deeper without the need to make the cabinet larger to achieve the same thing. It can also help dampen any resonances inside the cab.
Old 16th November 2012, 09:04 AM   #94
Art
The guess was for the ported/sealed combination. It was an off the cuff guess based on the slightly more peaky looking response of the yellow trace at higher frequencies. Its not always that easy to identify subs off graphs once eq is applied, you need things like impulse response measurements etc, time based measurements are important. An LRC is a Linkwitz Reilly Crossover.
I sold all my AV about a year ago due to moving country, and the recession has prevented its replacement, so I cant currently do any testing of my own unfortunately.
Old 16th November 2012, 01:40 PM   #95
The group delay and phase response don't really matter much below about 60-80hz, everything you'll hear in room is going to have a bunch of reflections.
Are you going to cross this to your mains with 1st order filters, and time correct the mains to the subs? Because that will make a much bigger difference in perceived transient response, especially in the midbass.
You can model parametric EQ's and filters in winisd, and you'll see that these also have a major impact on phase and group delay.
Do not be afraid of ported boxes. When built well (stiff, damp box - internally coated plywood), with a proper sized flared port(s) and a low tune, they sound just as good as a sealed box and are more efficient. They key is to have a mildly sloping response that blends with your room but still gives you a bit of "house curve", and to EQ out any room nodes.
Old 17th November 2012, 03:01 AM   #96
Bugged that I wasn't able to play with WinISD before leaving from work today. I really have to get a windows installed on my macs at home. This sucks.
I really hadn't given the crossover or time correction any thought! I guess this is a good time.
My mains would be powered bookshelves with balanced XLR or single ended RCA inputs They are fairly flat till 40 Hz.
Not sure how to do this, or what I need. I believe the Inuke DSP amps have crossover functionality (and time correction?), but they only have a single pair of outputs, which will go to the sub, and no line level outputs for high pass. I guess I have to either 1) run the speakers in parallel, or 2)place a crossover after the signal leaves the preamp dividing the signal between the mains and the inuke.
The advantage of #1 is that I can dedicate a high pass crossover to the mains, and let the inuke take care of the sub (basically each unit has its own filter); the advantage of #2 is simple single crossover. Does that even make sense?
I have no idea how this may pan out - or what all this really entails. This is really giving me the newbie blues!
Any ideas of where to start?
Turbodawg, I think you are right. In the perfect listening room, the argument may be valid that sealed is truly better, but in real world, common living room, a well made ported is definitely more useful. I agree. I like the idea of efficiency, but I don't know why I am still skittish of getting the tuning right in a ported sub. I really feel like I don't know what I am doing, and the learning curve is so steep, I am scared that once built, if I don't like it, it will be the end of DIY form me.
I am hoping that with running stereo subs, with real inroom reflections, a sealed sub will not require too much Eq and a single stereo inuke 6000 will be ok. I am hoping...
But for project # 2... ported experiment for sure!
Old 17th November 2012, 04:07 AM   #97
Would miniDSP be worth the investment? approx $125 for the balanced version.
It would be line (low level).
Old 17th November 2012, 06:30 AM   #98
weltersys's Avatar
Most any DSP is worth the investment if you are serious about integration of the sub to the main speakers.
However, to properly integrate the subs to the mains, some measurement must be undertaken.
Most dismissals of various sub designs are due to lack of actual measurement, a requirement to achieve the best response.
Old 18th November 2012, 03:58 AM   #99
I think I have settled on the idea of two sealed subs, each with the 18" Dayton reference sub.
The more I have read, the more I realized, the importance of measuring and correct EQ - phase, timing, and the right amount of boost for my room - and know that I will need quality DSP. My DAC/preamp is awesome with >120dB S/N ratio, and I really want to try and preserve the quality at least until my amps/mains.
I am still very confused with what to power the subs with and how to DSP. I thought I was settled on the inuke6000DSP - until I kept reading...
The Behringers come in 5 "flavors". And I still can't seem to find what a significant difference in these amps - other than the obvious inukeDSP having the DSP.
iNuke - not considering.
INukeDSP - has DSP
Europower EP - best deal.
Europower EPQ - not considering.
Europower EPX - nice, but relatively expensive.
Does anyone have any experience for the above amps - their differences?
I was contemplating b/w iNuke 6000DSP for $450, vs the EP4000 for $280, along with a miniDSP for $125. That deal on the EP4000 is unbelievable - if the amp will serve the purpose that is. The Europower amps seem to have better power stats and damping than the iNukes. The EPX is relatively expensive (EPX 4800 is $400 - without DSP) and therefore was not on my "short list" - should it be?
There seems to be an advantage to me of using a miniDSP is that it will serve as a line level HPF for my mains as well, and I can phase/time adjust the subs/mains all in one place. The S/N for it isn't that hot though. I could simply run my mains full range, and crossover the sub even lower - about 40Hz if using the iNuke option - but that will be a waste to me as far as offloading the mains LF to the sub. I was hoping to crossover b/w 60-80.
What I didn't like about the iNuke DSP is that there is no HPF for the mains at line level.
Any other suggestions, thoughts? Could I just get a cheap passive line level HPF for the mains? How would I time/phase adjust the DSP in the iNuke if the mains are not connected to it? Maybe I don't quite understand how this all works.
I could go for the higher end miniDSP - but even with the great deal on the EP4000 I am pushing well above $1000 system cost - but will be forced to consider it if there is a consensus that it is necessary for my goals.
Secondly, regarding the cabinets, is there an advantage to work with certain woods, or can I just go to the local Curtis Lumbar, and pick up some nice looking wood and stains.
Thirdly, when ordering the subs, (and amps), what other hardware, should I get? If using >1" baffle, will the standard screws be good enough, or is there value in using bolts?
Lastly, if I am running dual subs in this configuration, what q should I be shooting for in WinISD to measure out the cabinet size. As suggested by Moonfly, I should keep it below 0.7 due to room, and dual sub influence (see post 93), but question if how low - 0.6?
Thanks for all your help so far.
I really want to place my order and get cracking on this!
Old 19th November 2012, 11:11 PM   #100
woof is offline woof  United States
Late to the party, but this is my baby with 3 of the 12 ohm NHT 11-083 subs in a sealed enclosure.Introducing Towering Subferno
What are the pros and the cons of those 3 vas ? tessier Solid State 93 30th January 2017 01:53 PM
Newbie question: Pros/Cons of a Preamp after a Bufalo III ElEsido Twisted Pear 3 29th June 2011 06:40 AM
Cons / Pros Borat Tubes / Valves 34 1st September 2009 12:52 PM
Vertical WTMW driver alignment - pros and cons jb0194 Multi-Way 1 16th November 2008 09:20 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 05:37 PM
Copyright 1999-2017 diyAudio
