1.5" baffle thick enough for TC Epic 10" with 500W?
Old 11th November 2012, 01:54 AM   #1
Kooshball is offline Kooshball  United States
Default 1.5" baffle thick enough for TC Epic 10" with 500W?
I plan to make a sub enclosure with a 1.5" baffle that will be routed in ~0.65" to allow for a flush mounted Epic 10"...so I will be left with less than 1" of MDF to screw this beast to...will that be enough and is the 1.5" baffle thickness enough?
THX
Old 11th November 2012, 02:26 AM   #2
m R g S r is offline m R g S r  United States
Can't use bolts into threaded inserts?
The thickness isn't the problem it's the MDF itself I wouldn't trust.
Old 11th November 2012, 02:31 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
MDF is a sucky material for subs. if you use good plywood, no problem.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th November 2012, 04:44 PM   #4
weltersys is offline weltersys  United States
weltersys's Avatar
THX
Depends on the size of the baffle, 3/4" is perfectly adequate for a 12" square with a 10", while a 1.5" unbraced baffle in a refrigerator size cabinet would be floppy.
Why are you planning to flush mount the driver?
Old 11th November 2012, 05:27 PM   #5
Baffle is 1.5" thick, the rest of the components are .75"
I plan to flush mount since I think it will look better.
Old 12th November 2012, 05:16 PM   #6
weltersys's Avatar
I won't argue aesthetic points, but the baffle, presumably having the least area to flex, will not be the weak point, the rest of the .75" components are.
That does not imply that properly braced .75" is inadequate.
Old 12th November 2012, 05:35 PM   #7
geraldfryjr is offline geraldfryjr  United States
Even my 8" RS sub makes my 3/4" X 9" X 17" baffle profusely vibrate.
Even with a brace in the middle of it to the back board and it resonates at around 200hz to 250hz.
It sounds really bad with a sine sweep test.
But it is not as noticeable with music playing.
I also used particle board instead of some good plywood as it is very expensive to use.
FWIW
jer
Old 12th November 2012, 05:49 PM   #8
There will be lots of 3/4" ply bracing and the sides of the cabinet are curved so that should improve stiffness as well...
Cabinet height is ~18" and will have two braces horizontally from front to back.
I am more concerned with the weight of the magnet pulling the fasteners out of the MDF...that is what was included with the sub so maybe i am over thinking it.
Old 12th November 2012, 06:06 PM   #9
weltersys's Avatar
For home use pull out due to driver weight won't be a problem, but T-nuts would definitely be needed on the road with a heavy driver mounted to MDF.
A drop of glue on the screw tip and head can help prevent spin-out from vibration.
If the fasteners do strip out, you can always add T-nuts later .
1.5" baffle thick enough for TC Epic 10" with 500W?Hide this!Advertise here!
TC sounds epic 10 and useable frequency response Kooshball Subwoofers 3 16th September 2012 02:50 PM
FS: TC Sounds Epic 12" and 15" drivers davidespinosa Swap Meet 3 28th January 2012 05:55 AM
FS: TC Sounds Epic 12" and 15" drivers davidespinosa Swap Meet 23 13th January 2012 04:29 AM
Wanted: TC Sounds Epic 12" DVC Subwoofer CZ Eddie Swap Meet 0 4th October 2011 03:46 AM
WTB: FELT F13 Grey - 1/4" to 3/4" Thick - Like on Duntech/Dunlavy Speakers' Baffle dtm1962 Swap Meet 0 21st October 2006 04:18 AM
