hog scoop wil have the low corner between 40 and 50 hz,depending on the driver.
the scoop wil be much more efficient then br.
i personaly like the dynamic sound of scoops over br.
when you have an eq you can boost the low end of a scoop quite a bit .
you should realy sim the speaker to see if it works wel in a scoop.
see if i can find some hr inputs for the hog scoop.
can you post the ts parameters of the xb18.
FS Hz 33 Hz
RE Ohms 6.5 O
Qms 5.77
Qes 0.358
Qts 0.337
Vas Ltr 236
Vd litres 0.803
CMS (mm/N) 0.13
BL T/m 25.9
Mms (grms) 173
Xmax (mm) 7.5
Sd (cm2) 1131
Efficiency % 2.3
Le (1k Hz) 1.99 mH
whe can see here ,the driver unloads at 30hz or so.
i do reccomend a hpf ,but that go's for br too.
the fane works pretty good in the hog scoop.
1 and 2 pi simulation
amp is only powerful enough to damage at around 20 hz and below, takes quite a lot to reach xmech (17mm or something) (I tried unloaded) and I will high pass at 25 hz (the only option I have).
How does sound quality compare to a standard reflex tuned around 35 hz? At a reasonable volume say 105-115 db (1 meter) which would sound better? Thanks.
Thanks for the sim also, really appreciated.
if power is limited,i would deffenetly choose the scoop
- Subwoofers
- Fane XB 18 in Hog Scoop
